Question about Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
Max psi on utilitech water pump
What is max psi on this pump?
2 Suggested Answers
  • 512 Answers
SOURCE: I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Posted on Sep 16, 2012
I have a 1/2 horsepower Utilitech pump hooked to a 36 gallon utilitech tank and need to know the cut in PSI
For normal house service cut-in is usually 20 psi, cut-out 40 psi. The pressure switch can usually be adjusted to 50 psi. For any more check the pump specs. Usually you can google that.
Aug 18, 2015 | Plumbing
Just installed a MQ 3 -35 in my home in order to improve low city supplied water pressure (35psi). Now my home pressure is at 75 to 80 psi, too high. How can I regulate the pressure down to 55-60 ps
proper way is to install a water pressure regulator and due to potability reasons it needs to be brass ,bronze, stainless steel, or CPVC plastic , (no steel or cast metal) of course the less high tech way is to plumb a valve from pump outlet back to its inlet and adjust valve to max pressure setting you want at max demand , I don't recommend this method as it wont be able to give you a constant pressure regardless of demand as the first method will , Note: some water regulators are a "relieving" type and require special install methods and maybe three lines to it
Aug 16, 2015 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Utilitech 1/2 horsepower keeps turning on and off
cycles? Most likely your pump cant get enough water through it to cool the motor. The internal overheat protection cuts it off. I suppose after a certain amount of time it turns on again and does the same thing? Make sure there is enough space for water to flow at max rate through the intake. I suppose it could have trash blocking the flow both the outside "screen" and internal pasage to the pump impeller.
Mar 09, 2015 | Garden
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
What is max. gpm and pis of the wisperflo punp 011773
Your question sort of requires two answers as the max flow and max psi are not the same yet relate to one another.
The max flow is ~105 gpm at ~26 ft./hd or 11.3 psi.
The max psi (head) the pump can operate under is 40 psi or ~85 ft./hd at which flow is ~35 gpm.
In other words, in a pipe system with low resistance it moves up to 105 gpm and in a very complex system with lots of elevation changes and a lot of resistance the pump will move about 35 gpm.
PSI as read on a gauge on a filter attached to this pump will NOT be the same as the ratings I am giving you here.
John
Aug 24, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
Re: Creaftsman 2700 psi washer, model 580.752100 - I cannot use the detergent cleaning tank. The pump forces water into the tank, and it overflows onto the ground. If I try using the washer with the...
The is a small tube that attaches your chem tank to the pump...detach the tube from your pump and remove the nipple from your pump. There is supposed to be a ball and spring inside that nipple. This is a check valve for your chemicals...it isnt working. Alot of times people take them of the try and fix something and lose the ball and spring so be careful. More than likely your spring is broken and just needs to be replaced. Good luck
Sep 04, 2017 | Craftsman 2700 Max Psi Pressure Washer 23...
JUST DON"T KNOW
I have one also all it required is 2stroke engine oil
May 11, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100 Logo
104 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
