Question about Garden
Relacing starter rope on a nupower npcs45cc chainsaw
REPLACING STARTER ROPE
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
SOURCE: Attaching starter rope to pulley
The factory method is to bring the pull cord through the hole on the outside of the pulley, wrap clockwise once around the cogged part of the pulley, then over the pull cord and a clockwise wrap under the screw with the searated washer.
Posted on May 28, 2009
mowerman1857
  • 389 Answers
SOURCE: the starter rope broke on my Toro mower and the
I cannot believe that someone suggested grinding off the rivets. If the bottom portion of the rivet falls down and gets caught by the magnet on your flywheel and you try to start it you are going to do some SERIOUS damage.
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank2.gif to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Posted on Sep 18, 2009
  • 279 Answers
SOURCE: how to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Posted on Nov 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: starter rope broke how do i replace it
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
Posted on Apr 23, 2010
How do I relace the starter rope on my pressure washer?
Remove the spark plug and pull the starter rope
Aug 13, 2014 | Garden
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
Replacing rope on a strimmer
Check youtube for a video on how to place a starter rope on the starter cover of your saw. Once you see the visuals, if your pretty good with your hands, can see how they wind the spring , and place a new rope on the starter .
May 09, 2014 | McCulloch Mucculloch 330 Motor Housing...
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Need to relace starter rope
    Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    How do you rewind the starter rope spring on an Echo PB-200 Blower.
    assuming the spring has not broken behind the pulley causeing this problem you should be able to just re tension the spring, hook the starter rope into the slot in the side of the pulley, this will allow you to wind the pulley ( in the direction that the engine rotates ) up, when you have turned it enough times that the spring is coil bound ( be careful as the spring will be under a great deal of tension ) release the pulley then one whole turn, now unhook the starter rope and allow the spring to recoil ( dont just let it fly back ) and wind the rope in.
    Feb 04, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
    Starter rope will not pull. Will pull smoothly
    If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
    Lou
    Sep 17, 2009 | Bosch Garden
    Poulan starter rope
    to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
    Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
    Garden Logo
    66 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
