Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Blower motor suction
I have jenn air Model# sve87600w and the down draft blower baerly sucks the smoke if i cook 1 hamburger it will fill the house with smoke. I had a repair man out and he said everything is fine. how do I know if blower motor is working properly and it is spining fast enough to draw the smoke.
    Novelist:
  • 88 Answers
You may want to check the venting on the unit, motor may be fine, but sounds to me like you may have a collapsed line, or a plugged line, I would also make sure nothing has gotten down into the venting chamber at the top to clog it, hope that helps
Posted on Jan 20, 2009
Jenn Air oven Model: jgs9900bds16 "warming drawer" lights up
If it is not affecting the performance of the machine, disregard it.
Jul 30, 2013 | Jenn-Air Kitchen Ranges
I have a Jenn-Air JGS9900BDS purchased almost new at a scratch and dent place last year. The downdraft is blowing air out versus sucking air in. Because of we fired our contractor, we can't go back to...
I just installed a JES9900BAB that I got from a Sears Outlet Store two months ago. The blower motor had a sticker on it that said not to reverse the motor and intake sides because it would not operate correctly. I bet your contractor actually disassembled the motor and reversed the intake 180 degrees in order to make the installation easier. This would cause the down draft to blow instead of ****. With the exhaust of the fan, part that goes through the floor, closest to the back of the range, the inlet should be on the left and the motor should be on the right.
Nov 30, 2010 | Jenn-Air JGS9900BD Gas Kitchen Range
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
Jan 25, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-air downdraft blower doesn't work
thiknin thats a sealed unit, however imn sure they got it into a housing so i guess if you lloked close enough ther ewpuild be a few screws to gain access to the fan itself and with it open a quailty degreaser should work wonders in cleaning it!
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
227 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
