Question about Refrigerators
Manitowoc QY0324A strange problem
I have a manitowoc QY0324A that worked fine before not working.The board just got replaced and the machine cleaned.The cycle seems to be ok besides the fact that it goes into harvest after a couple of minutes and obviously doesn't make any ice. Before anyone asks, I unplugged the water pump and made sure the evaporator froze up. Also the new board bulletin says NOT to wire the water level sensor and I tried that but then the water doesn't switch of... any ideas ??? I'm all out ! thanks
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: I have a KitchenAid Side
Hello Tom,
I see where ya said the water dispenser works good and thats cool! when you do get the i/m to run the ice harvest cycle are the cubes full size? if yes the water supply can be ruled out as a possibility. Besides the water not seeming as cold are other things in the fresh food compartment NOT as cold as they are not as cold as in the past,if yes try removing the grill below the doors and clean the dust from the coil there,if it isn't there its the rear of the ref. by the compressor. One of the first things to be affected when a ref is working hard to keep things cool due to a dusty coil is going to be the icemaker,it will freeze the ice but the internal thermostat inside of the i/m module isn't satisfied its cold enough to start the harvest. When jumping out the T&H what exactly your doing is jumping the t-stat regadrless of the temp. of it ,causing it to run a harvest cycle
I hope this answer helps you,
Gene
Posted on Aug 05, 2011
My Manitowoc Ice machine will not produce ice. The harvest light is on and it will run through the clean cycle
Hi, contact your local appliance repair facility, you may have problems with the control board, the ice level sensors or curtain.
Nov 26, 2017 | Manitowoc Kitchen Appliances - Others
I HAVE A MANITOWOC QM30A ICE MACHINE. WILL THE LIQUID LINE THERMISTOR CAUSE IT TO RUN BUT NOT MAKE ICE?
Liquid line sensor on ice machines in general is used in conjunction with the control boards to determine defrost and harvest cycles. You could measure the line temp and chech the resistance of the sensor to check it.
Betabass
Sep 07, 2016 | Manitowoc QM30A Self Contained 65Lb...
Won't make ice in cold weather
Check the thermostat of your Ice maker whether it is in working condition or not. For More information please visit GE Ice Machine Cleaner.
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
I have a Manitowoc s-450 with a AuCS-SI installed and it is set to not clean at this time. The machine is stuck in cleaning mode and is partially refrigerating. I disconnected the AuCS and it works fine....
When a Manitowoc goes into clean mode,It stays in clean mode until it finishes.If you turn it off and then on again,it just keeps cleaning.Let it run in cleaning mode until it finishes
Aug 24, 2010 | Manitowoc 450 Lb Ice Cube Machine Self...
Manitowoc QY1304A Ice Machine Compressor will not start
Does the compressor make any noise at all?
You can ohm out the compressor windings. I dont know off the top of my head which compressor manufacturer they are using but if it is Copeland you can get an electrical handbook and it will have ohm values for the compressor. If not assume the rule of thumb Common to Run is X, Common to Start is Y, Start to Run is X+Y, and Y should be 3 to 5 times whatever X is. On Rx10,000 scale check each terminal to ground should be open.
Aug 06, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice machine starts on harvest mode and will not go on to production
you will have to find the main board unplug the connector for about a mintue plug back in. This should reset unit
Aug 05, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
