Question about Transmission & Drivetrain for Isuzu Amigo
Auto trans not holding gears slipping in and out
    New Friend:
    Problem Solver:
  • 18 Answers
Buy fluid for slippage auto parts store
Posted on Jan 05, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Auto Trans will not go into top gear all others work okThis is a Surf.Will change into all other gears but will not change to the top gear.
Each gear is activated by a valve shifting and this valve is energised by a relay within the transmission. Your problem could be either of these or related to a computer problem. Only way to solve is have a transmission shop diagnose the problem. Trans. fluid and filter need to be serviced according to the owners manual. Pull the trans. dip stick if you have one and smell the fluid. If it has a burnt it for, the discs could be slipping. Either way a trans shop is your best bet. Good luck. Roger
Nov 22, 2017 | Cars & Trucks
Trans. slips 99 isuzu trooper
no response so
so less
1:will it slip parked, idling, in drive,foot
on brake,? then advance throttle and see like 2000rpm but fails and goes why higher?
that is the stall test failing,
2:fail in reverse, parked?
fail only moving
gee,,,, can you say more than SLIP?
Feb 19, 2017 | 1999 Isuzu Trooper
My 2003 gmc sierra has a shudder from 1st to 2nd gear it allmost like it slips outa gear for a second and then catces and shifs into second any suggersions on what the problem could be?
Hi
I assume it is and auto, if so firstly check auto trans oil level as per manufacturers instructions.
If all OK will need to take it to Auto trans specialist as I suspect removal / overhaul is required.
(NB = Get written quote before proceding as this job may be expensive)
Dec 10, 2009 | 2003 GMC Sierra 1500
Code p0734 4th gear ratio auto transmission
this means the trans is slipping as measured by the input and output shaft speed sensors.
Dec 09, 2009 | 2004 Nissan Altima
I have an automatic trans mission that doesnt go
The forward gears slip but dose the reversr gear slip as well if not your problem is either the forward band is worn out ,,,,or the forward pump is playing up and also it could be the thing that starts it all off is the filter in the auto sump is clogged up with metal or drive band dust is the colour of the auto oil dark or dirty..
When was the trans oil last changed.
Oct 10, 2009 | 1995 Jeep Grand Cherokee
Auto transmition wont go into 3rd and 4th gear
I had the same problem I changed the transmission fluid & put a new filter in the trans, this fixed it good until I put my foot down to overtake the trans kicked down to 2nd gear & the hold light started flashing again & the trans started slipping again. I stressed over it for a day or 2 & then I took it out for a drive & thrashed it, Low & behold it came right. When you change fluid its impossible to get all the old fluid out because the torque converter holds a liter or two under pressure, so when I put my foot down some of the gunk blew through & blocked the pump it looses pressure & cant change gear. You need to get it flushed by a transmission specialist
Apr 23, 2009 | 1996 Mazda MX-6
88 toyota supra auto trans slips. won't up shift to 2nd gear
yep, sounds like your transmissions on its last leg, mabye you can get by, by starting in 2nd, if you have the option lol, but auto tran's are pretty cheap on ebay or try www.supraforums.com seen one for 300$
Apr 02, 2009 | 1988 Toyota Supra
Transmission & Drivetrain for Isuzu Amigo Logo
53 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
Rick Wrieden
Rick Wrieden
George Agios
George Agios
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
