Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Center post on 11 year old side by side amana is hot
The refrigerator and freezer are still working fine but the center post is very warm to the touch and both gaskets are warm. sometime there is a high pitched whining noise. can you help?
After checking all of that..
Try unplugging it for a couple of minutes then plug it back in. I found on my 27ft Amana side by side that the defrost control is controlled by a microcontroller based module near the bottom of the fridge. It was out in la-la land and in my case, was not defrosting the freezer coils. Cycling the power reset it and all was well.
Worth a shot. Good luck.
Posted on Jan 22, 2009
  • 410 Answers
Check the coils underneath the unit to be sure they are clean if they are clean then check the condenser fan motor behind the cardboard cover on the back of the refrig. the motor could be bad or has an obstructuction. good luck peyton
Posted on Jan 20, 2009
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
We own an Amana bottom freezer; Mod.# BC120TW, Ser # 9708176268. It is approximately 10 - 11 years old. The freezer is not getting to a low enough temperature. We have soft ice cream etc. I have cleaned...
If it is constantly running, (compressor and the fan inside of freezer) then the thermostat is working, more than likely you have an inefficient compressor or a low charge in the sealed system due to a refrigerant leak. Touch the compressor, is it almost too hot to touch? Do you hear a buzzing and clicking noise every so often? If you can answer that for me, I could better diagnose it
Jun 15, 2009 | Refrigerators
Amana Top Freezer Refrigerator is hot to the touch on the outside on the sides by the freezer. Still working fine inside. Is something getting ready to break inside?
The problem was the fan. It was hitting the metal enclosure and had stopped working. We made an adjustment and cleaned it and now it works fine and the hot spots are gone.
May 04, 2009 | Refrigerators
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer on bottom cold but frig is warm
Just additional clues..(general). The defrost timers (on non-electronic) usually located at the bottom (underneath), have a tendency to fail. (One of mine is in the center, one was on the left side) There are usually about 5 wires connected to it. If it fails while defrosting.. the fridge will warm quickly and stop cooling, if it fails in cooling mode, you will have the icing up problem. (other) A squealing noise is usually a fan motor. -also- (Freon issues)..as freon is lost from a small leak, first the freezer will actually get colder, but the refrigerator section may be too warm (I know it sound stupid). When enough is lost the compressor will get hot and the fridge will not cool.
Jan 02, 2008 | Amana ARB8057CSL Bottom Freezer...
Maytag side by side fridge.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
172 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
