My NEXTBOOK tablet won't connect to the wi-fi. Keeps saying "obtaining IP address"
    New Friend:
  • 3 Answers
Something could be getting in the way of the connection or your ip number may not be working. see if it will allow you to enter the ip address which should be located on your wifi box.
Posted on Jan 05, 2013
    Sergeant:
  • 279 Answers
If your WiFi works fine for your other WiFi-enabled devices, then the problem is the tablet. Android devices, in my experience, were always flakier with WiFi for some reason. Does your tablet connect to WiFi at other locations?
Posted on Jan 04, 2014
How do I get a new IP address for my next book android 4.0 tablet it is saying unavailable
Most Android devices have an IP address only when they have connected to a router, usually by wi-fi (other times it isn't needed).
When connected go to the Settings menu, tap Wi-fi, then tap the name of the network you are using. The device IP address should be listed .
Nov 04, 2015 | Tablets & eReaders
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Apr 13, 2015 | Nextbook Premium 8 Se Android
My tablet keeps saying Avoided poor internet connection every time i try to connect and ive tried everything reseting, turning on/off the wifi everything and it still wont work
If other devices work ok on the same Wi-fi, then the tablet should, as long as it's near the Wi-fi router but not too close to it.
Mar 24, 2015 | Nextbook Next3 tablet
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Dec 27, 2014 | Amazon Kindle Wireless Reading Device
How do I correct a wi-fi error code?
If there are any networks detected, forget that network. Then set it back up again with same network. If that doesn't work call your wifi provider
Sep 19, 2014 | Nextbook Premium 8 Se Android
Wi-fi not obtaining IP address and if turn off wi-fi can not get to turn back on
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
May 31, 2014 | Coby kyros Tablets & eReaders
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Psp connection to internet
You probably have your wi-fi under secured network.
Oct 02, 2008 | Video Game Consoles & Games
Computers & Internet Logo
929 people viewed this question
David Payne
David Payne
