Question about Sony STRDH520
Sony Receiver STR-DH520 shuts off every 30 minutes when playing DVD
Does not do this when watching TV. All was well until someone played with settings when trying to hook-up an old VHS player. Now when set on BD/DBVD to watch a pre-recorded DVD the receiver shuts off after 30 minutes of play time.
SOURCE: Sony STR-K660P Intermittent sound problem
xdfcbzdf
Posted on Mar 13, 2008
SOURCE: sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Posted on Dec 30, 2008
remington870
  • 48 Answers
SOURCE: Getting the best out of my Sony STR DE-475
Yes, it would downgrade.
Simply run an HDMI cable to the LCD from the DVD player. Now, use the digital audio output of the DVD player to run to the receiver. I know the Sony has an optical input which i recommend over the coaxial input as the optical cable doesnt waste any energy as a medium transferring sound since its only light.
Posted on Mar 31, 2009
joshter32
  • 82 Answers
SOURCE: I am setting up Sony A/V Rcvr and cannot get video
hi my names josh your feeds arent going to feed out through that hdmi if your have hdmi coming in you will get that signal going out however depending on what your signal source is for the rest of your compenents that will determine your problem for instance if you if your runing all compenent which y p b or video which is just standard yellow red and white cables you have to stay with one or the other what you go into your reciever with you must go out with if analog wich is just video and audio you have to go out through your monitor out source to get a picure if compenent whic by the way will produce a far greater picture it is your y p and b jacks and the color of those are green blue and red those are just for picture only not audio you have to still run audio with these cables you go in the unit with those you have to go out with those directly to your tv then you want check you reciever video setting to make sure it is set for that and well as your tv to make sure you are in the right monitor or screen to get your picture
Posted on Oct 31, 2009
Testimonial: "Okay, thank you Josh. Your message is difficult to read. Short complete sentences would make your solution clearer but I believe I understand. Thx."
SOURCE: I have my 80 gb PS3 hooked up to my STR-DH800. I
if you have the old fat ps3 it will only output linear pcm through hdmi.if you have the new slim ps3 it will output the true hd and dts master audio through hdmi.there is nothing you can do about it as far as i know.i hoped sony would fix this but so far they have not
Posted on Jan 30, 2010
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
STR-DH520 Sony av receiver , Protect sign keeps coming on and I have no wires connected at all! How can I fix ??
There is most likely a short in the amp that needs to be repaired. Probably a pair of shroted output transistors as well as a few resistors will need to be replaced.
Dec 17, 2014 | Sony STR-DH520 A/V Receiver
Receiver won't play music from an MP3 device
Use your computer speaker as the sound device or use a headphones.
If it sounds good, it could just be your cable that goes to the receiver.
( using a Y cable to connect to one of the regular audio inputs.)
or have one like these:
3.5MM To Stereo Rca Cables: Electronics
Sep 25, 2012 | Sony STRDH520
Mar 29, 2009 | Sony STR-DE475 Receiver
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
Sony str bd-930 connected via digital input to ps3,no sound..
Nov 16, 2008 | Sony STR-DB930 Receiver
Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
Jan 24, 2008 | Sony STR-DG800 Receiver
Cracking and poping with Yamaha surround sound system
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
How do I get video input from one source and audio from another?
I am confused and might be overlooking something obvious here. SO PLEASE do not think I am being disrespectful! IF you have everything connected properly, then your television is a separate device, independent of your Sony STR. You should be able to watch the picture with the Sony STR turned OFF. In turn, you should be able to LISTEN to the Sony STR with the television turned off. Although it isn't a lot of fun, it might be best to DISCONNECT all the cables (not your speaker wire) and go through the process of reconnecting everything.
Jul 09, 2007 | Sony STR-DE597 Receiver
Sony STRDH520 Logo
76 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
