Question about Sony KP-57WS500 57" Rear Projection Television
Sony kp-65w5500 rear projection TV red tube needs replacement
Anyone sells this product? Sony no longer makes it. The TV is 6 years old and can't get it repaired. Any help would be appreciated.
    Problem Solver:
There is a company called Video Display Which sells rebuilt tubes
Posted on Jan 19, 2009
SONY KP41 S3U where can i get a lamp from and are they identified by tv model or by lamp number
This tv SONY KP-41S3U doesn't have a bulb, it's an older CRT tehnology: the image is created by 3 small tv tubes.
If one of this tubes has failed then the tv is dead - the tubes have been taken out of production 5 years ago and you can no longer find them.
Time for a new tv.
Dec 01, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
SONY KP-46C65 PROJECTION TV
we have repaired 100s of these tv..most have a flicker issuse and it is getting hard to find replacement tubes. the cost sounds right...I suggest to invest in a new tv.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Replacement lamp/bulb sony kp-61hs10
that model number doesn't use lamps it uses cathode ray tubes projection tubes. the CRTs for that tv are probably no longer available.
Feb 22, 2008 | Sony KP-61HS10 61" Rear Projection...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP -57HW40 - Green Picture Tube - part new/used
CONTACT VIDEO DISPLAY AT 1-318-747-0140 AND TALK TO CHARLIE I GOT MY BLUE ONE FIX IN 6 DAYS!!! AMAZING FOR ONLY $152.00 THATS CHEAP YOU JUST HAVE TO SEND IN YOUR OLD ONE AND THEY REPAIR IT! AWESOME COMPANY!!!
Nov 27, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
355 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
