I have windows xp an error message box pops up that says at the top message from webpage [object error] it wont go away after xing it hitting ok or alt control delete. Everthing is locked up depending on that box to be gone.
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer this may vary depending on your computer and operating system If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details or You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps. Hope it helps.
Posted on Jan 05, 2013
  • 239 Answers
SOURCE: start up problem
It sounds like your Hard Drive may have went bad, My dell C640 did the exact same thing, I was able to get it to work a couple of times by taking it out and shaking it a little its kinda hit and miss if you can get it to work that way, But if you can save all your files to a storage device right away so you don't loose it all, and thats if you can even get it to fire up for you. I am almost positive thats the problem. You can get a new one from the manufacture or off ebay. Hope that solves you problem, The reason it won't boot off the install disk is the hard drive is not working anymore, Alright take care If you need help finding or how to write me back
Posted on Dec 22, 2007
iZen
  • 28 Answers
SOURCE: compac deskpro Pentium 111 - 600
I'm not completely sure on what you are exactly asking here, but I'll do the best I can. If you have the Recovery CD, you need to boot from the CD and run the Recovery. When you go to do the recovery you will have two options, the normal recovery or the destructive recovery. If there is nothing important and everything can be wiped, run a destructive, but if you need everything run the other one. If you do not have a Recovery CD but have a Windows Vista disk that matches the version on your computer (IE: Windows Vista Home 32 bit is on your computer and you have a Windows Vista Home 32 bit disk) and you DO NOT need anything saved, just reinstall Windows. There is a product key for Vista on the sticker attached to your case. If you have neither, then you can probably get a new recovery disk by contacting HP (since they bought out Compaq). If you can not get a new Recovery CD, you will need to go out and buy a new copy of Windows Vista.
Posted on Feb 21, 2008
jeyzie
  • 59 Answers
SOURCE: as soon as i ctrl-alt-delete
i think you need to install your keyboard if you still having problems with that i suggest that you change your keyboard or you can also try to reformat your computer cause your keyboard might not be recognize because of the softwares that you have. hope it helped
Posted on May 04, 2009
  • 67 Answers
SOURCE: keyboard suddenly stopped working - can't turn off or Control Alt Delete
  1. Disconnect power supply
  2. Remove battery
  3. Wait 30 second
  4. Reïnsert battery
Posted on May 05, 2009
babes_ganda0
  • 381 Answers
SOURCE: ZT Group CISNET A7022 disk read error
this error can not read the order to your CD / DVD player or damage to your CD installer, try to install or use a different installer CD and when both said that problems can be your Player of the problem, hopefully it helped you.GOOD DAY
Posted on Aug 01, 2009
Make google your homepage
In Internet Explorer. Go to Tools in the upper left hand corner, then in that box click internet options at the bottom. A box will pop open.
In the top of that box will be an address. Delete it and type www.google.com then hit ok at the bottom. Do not hit apply, hit ok. Should be good to go. Open a new webpage to make sure it stuck.
As a side note, if you don't see the line on top of your screen that says file, view, favorites, tools, and help do this...right click with your mouse on the top of the page ABOVE (not in) the address bar and make sure "menu bar" is checked.
Good Luck
Dec 07, 2013 | Computers & Internet
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0) Timestamp:...
restart pc,Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reginout
Dec 18, 2010 | Microsoft Internet Explorer 8
Error 1603
When you try to install a Microsoft Windows Installer package, you may receive the following error message:
Error 1603: A fatal error occurred during installation.
If you click OK in the message box, the installation rolls back.
To resolve this problem, do any one of the following, depending on the cause of the problem:
  1. On the Windows desktop, double-click My Computer. The My Computer window appears.
  2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties.
  3. Click the Security tab.
  4. On the Security tab, do the following:
    • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account.
    • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.
    If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box:
    1. Click Add. The Select Users or Groups dialog box appears.
    2. In the Name field, click SYSTEM, and then click Add.
    3. Click OK.
  5. In the Permissions section, click to select the Full Control check box underAllow, and then click Advanced.
  6. Do the following:
    • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK.
    • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.
    Note If you receive a security message, click Yes.
  7. Wait for the operating system to apply the permissions that you have selected to all child folders.
  8. Run the Windows Installer package.
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
Before Windows xp loadsi get a message to "unlock your keyboard" I cannot access my controlboard since xp will not load until I unlock the keyboard. I tried using a different keyboard but same message...
when booting hit f11fast and over and over til the setup options starts or f2 for the bios to pop up and route though til ya find the keyboard options ok if locked unlock or enable it, it is in one or the other or upon boot hit R many times til the recovery tool pops up and then do a HD error diagnostic on it to find the problem ok the fixist good luck and have a nice day
Jul 01, 2010 | Computers & Internet
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.0.3705; .NET CLR 1.1.4322; Media Center PC 4.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET...
This error message is not an issue on your computer. Check the following code:
'length' is null or not an object Line: 1
This is error in coding.
If you want you can reset your internet explorer settings by following the steps below:
1. Go to control panel and open internet options.
2. Click on advance tab on the top.
3. Click on the button says restore defaults or restore advance settings
4. Click on ok.
5. Close internet explorer and try again.
Regards,
Rashish Sharma
Mar 20, 2010 | Microsoft Internet Explorer 8
Webpage error detailsUser Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; SIMBAR
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; MAAU; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MAAU)
Timestamp: Wed, 21 Jul 2010 17:11:22 UTC
Message: Type mismatch.
Line: 179
Char: 1283
Code: 0
URI: http://api.msappspace.com/apprendering/152296/profile.right/07212010083001/1_0_0/render.app
Line: 179
Char: 1283
Code: 0
Message: Object doesn't support this property or method
Line: 279
Char: 17
Code: 0
URI: http://api.msappspace.com/apprendering/108417/profile.right/07212010080001/1_0_0/render.app
Line: 298
Char: 17
Code: 0
Oct 21, 2009 | Microsoft Internet Explorer 8
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
