Torpedo heater has fuel and fire but blows smoke unless I restrict air flow
The heater worked fine for the last year and then all of a sudden last week it started smoking when lit. I can take the cover off and run it and it seems to have both spark and fuel but will smoke off/on. (a lot of smoke) I finally decided to try reducing the air flow from the back by placing cardboard over 1/2 the intake and that seemed to help for about 10 minutes. Then it started smoking again. I replaced the ignitor but am unsure what to do next!
  • ewalkerpcs
    ewalkerpcs Jan 05, 2013
    So I figured it out. Was the fuel filter not providing enough fuel. Removed it, cleaned it, and put it back together. Worked like a champ! (will replace it in the daylight hours)
  • ewalkerpcs
SOURCE: UNIT LITES THEN GOES OUT BLOWING SMOKE
Pick the heater up throw It at the wall, the heater has been used to heat my uncles home no problem now it wont light, on the day its needed most outside in the freezing cold, so my solution was throw it at wall and go to walmart.
Posted on Jan 15, 2009
tinytrees
  • 92 Answers
SOURCE: Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Posted on Jan 22, 2009
tinytrees
  • 92 Answers
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
tbugger
  • 232 Answers
SOURCE: i have an older reddy heater pro 100 kerosene space heater,
You Must set the pump pressure quickly! If allowed to run with the nose cone a "bright" cherry red the welds will deterioate to the point that the end will separate from the combustion chamber. Individual sheet metal parts of the chamber are not available.
Learn how to properly set the air pump pressure
Posted on Feb 26, 2009
  • 224 Answers
SOURCE: I have a 55,000 BTU
Water in the fuel tank, I personally had this problem this morning irritating but was simple to cure. Empty your fuel in to a clean five gallon bucket and observe, fuel is lighter than water and will float on top water settles to the bottom. You now have to dry out the tank, get creative I stuffed mine with rags and sopped it all up, this worked fine for me. You can siphon off the fuel from the water and re-use the fuel. Just be careful not to siphon off the water with it.
Posted on Dec 23, 2010
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
I have master torpedo multi fuel when its cold it work fine but when kick on after its hot it wont it just blows smoke out and have to unplug it
fuel pressure could too high you could have a cracked rubber hose on the pump sucking air start with fuel pressure and that will help us to get started
Dec 13, 2010 | Milwaukee Tool Master Heater 165,000 BTU...
Shuts down after about 30 seconds, blowing some smoke.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
