Question about Air Tools & Compressors
How do you fix an air compressor - Air Tools & Compressors
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Difficult to answer without a make, model, or symptom, but common problems are the cord, pressure switch, check vavle, ring and cylinder, and valve failure. mastertoolrepair.com has a lot of parts breakdowns and can sell you parts.
Posted on Jan 05, 2013
Air compressor will not build pressure past 20psf
You may have dropped a valve in the compressor. Same thing happened to my compressor, and I've not actually been able to fix it.
Jul 30, 2015 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do I fix my pressure switch on my puma 6060 compressor
Need some details, exactly what is it doing or not doing incorrectly.
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
How to Fix an Air Compressor That Doesn't Build
  • If you are asking is it possible to repair a leaky air compressor tank the answer is no, not without risk of life or death. When the pressure builds great enough, what ever has plugged that hole, will blow out and it will hurt of kill whoever that plug happens to hit.
Regards, Tony
May 22, 2011 | Air Tools & Compressors
After starting the compressor, the tank does not fill up to 120 psi and shut the compressor off automatically. It will continue to run and not fill the tank completelhy. How can I fix this?
It could be one of three things. 1. The air intake could be dirty to the point that it cannot take in enough air volume with each cylinder stroke to be able compress it to 120. Try cleaning the air filter. 2. The reed valve that prevents the return of air from the tank to the compressor is not sealing well. This might be cleanable, but requires disassembly. 3. The cylinder itself has a poor seal giving you bad compression. This would require major surgery and parts, and is probably not worth fixing.
Jun 29, 2010 | Campbell Hausfeld FP2080 4 Gallon Portable...
My friends Craftsman air compressor stopped running
The compressor in question is basically a throw away.
My personal opinion is it's more trouble then it's worth.
Even after it's fixed you still have a throw away compressor.
However it is possible to repair it if the parts are still available.
Check out the link below for parts and diagrams for the compressor in question.
Hope this helps and good luck.
http://
www.mastertoolrepair.com/-c-271_535_537.html
http://www.mastertoolrepair.com/
Jun 10, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor runs not building pressure.
You MUST replace fixes never work.
Mar 28, 2010 | Air Tools & Compressors
How to fix compressor air gas 55 hp dewalt it
that is probably the top end for this machine. If not sure, visit the web site of the manufacturer.
Oct 10, 2009 | Dewalt 5.5HP 8GAL Gas Wheeled Portable...
The Air Compressor Smokes and Then turns off after a while.
sounds like the piston rings are blowing by allowing oil to get into the compression cylinder.
You should chuck it and go buy a new compressor as this one is more to fix than to replace.
Jun 01, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My central Pheumatic air compressor oiless
Sound like the fly wheel is loose or belt is the same
Mar 13, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do you fix a serpentine belt of air condtioning that is grinding even when air or defrost option is not on?
replace compressor ;remove refrigerant ;accessory belt ;electrical connectors ;suction /discharge refrigerant hose from back of compressor ;bolts from compressor and engine block ;leave bracket attached to compressor
Jun 06, 2008 | Oldsmobile Aurora Cars & Trucks
Air Tools & Compressors Logo
235 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
