Question about Canon imageRUNNER 5000 Copier
I need to change the toner to my canon super g-3 copier, How do I remove the old one?
  • kellicorners Jan 20, 2009
    It is notthe kind you just refill. It is the kind you replace the whole cartridge. I cant get the old one out.and your right it is a big mess...lol Thanks for the help anyway. I sure was hoping to do it myself. May try again. I know it pops out just not sure which way. Have a great day
    Still confused.:{
  • Canon Expert
  • 1,326 Answers
Have you adde the new toner in to the copier and can noy get the spent toner bottle OFF, right? Once you have locked the toner bottle in, you have to pull the Blue lever on the right bottom side of the toner bottle. That is pulled to the right to allow the toner to feed into the hopper. Once the toner is empited from the bottle, you have to push the Blue lever back to the left and push a little harder when it stops. This will release the two claws that hold the bottle locked in. You should be able to tilt the toner bottle up and to the left and then slide the toner bottle to the right and remove the toner bottle. If you can not get the toner bottle off, leave it till a service person comes or somebody else, don't force it, IT WILL MAKE A VERY, VERY, VERY BIG MESS...... The copier will work with it attached. Good Luck... I wouldn't ware white.....
Posted on Jan 20, 2009
HOW TO CHANGE THE CARTRIDGE?
Use the following steps.
1. Grasp the button on the left front side of the machine to open the top half of the copier.
2. Look for the black plastic toner cartridge on the right side.
3. Grasp a small handle on the right of the cartridge and pull it out of the copier.
4. Unpackage the new toner, pull the flexible toner seal out of the handle of the new toner cartridge.
5. Slide the new toner in place of the old and close the cover.
Instructions should also be provided with the new cartridge.
Aug 09, 2010 | Canon PC-940 Black and White Copier
Changed toner cartridge and still not printing entire page- mostly white space. How can I tell if it is a faulty new cartridge or problems with my copier. There is toner dust inside the copier from when...
First you need to vacume the spilled toner, especially on transfer roller, eaven clean the transfer roller contacts.
Try to reinstall the old crg., shake it so that you may get few copies for checking it. If print is OK then its problem in new crg.
Feb 23, 2010 | Canon imageCLASS D320 Digital Copier
Installing the toner cartridge
release the 'clamshell' and slide it in. I don't know what else to tell you
Jul 26, 2009 | Canon Office Equipment & Supplies
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
Need to change cleaner blade on drum
Remove drum unit, remove Drum, remove blade (2 screws)
** coat the new blade with some toner, or it will flip, when the drum start to turn, due to the friction. And always manually rotate it yourself prior to re-installation to make sure it is ok
Apr 28, 2009 | Canon C330D Copier
My Cannon Super G3 says wrong page size
Open cover, remove toner, close cover.... not sure why this happens, but this is the only way that we have found to get around the error. After doing this 3-4 times, it seems to reset itself and work just fine.
Nov 26, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Color toner
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
Nov 04, 2008 | Canon imageRUNNER 210S Copier
Canon Imagerunner C2050 changing toner
Did remove all of the packing off the cartridge before installing the cartridge. Also, is it the right type of cartridge for that you need and or the right color... It should be easy to install if you are installing the right cartridge... Good Luck
May 12, 2008 | Office Equipment & Supplies
Canon PC940 Problem
You could have a broken exposure lamp. Does the scan bar light up when you make a copy? If not that is the problem. You might also ck the contacts on the machine where they touch the toner cartridge. The toner cartridge opens a shutter to the drum when you slid it into the machine and that may be broken.
Feb 11, 2008 | Canon PC-940 Black and White Copier
Toner Cartridge IR3300
hi, when you purchase a new toner , the directions to replace is on package , try following that....
Jan 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 5000 Copier Logo
95 people viewed this question
old marine
old marine
