Question about Whirlpool duet Washing Machines
Electrical schematics and service manual for wfw94hexw duet 4.3cu ft front load washer
Looking for info on machine before I need it and dont have one.....:)
  • 13 Answers
SOURCE: Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Posted on Feb 02, 2007
  • 1073 Answers
SOURCE: Whirlpool duet Front Loading Washer
go over to the end of cycle button and hold in for 3-4 seconds and you have it fixed
Posted on Apr 15, 2008
SOURCE: Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Posted on Oct 03, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
SOURCE: Rotting Smell from Whirlpool Duet Front Loading Washer
Take the panel off of the front of your washer below the door and in the middle there is a round removable plastic door like piece. Take it out and clean out all of the junk in behind it. You might find loose change, nails and a variety of other thnigs that have become stuck in there besides mold. This will help with the smell and also the water that sometimes remains in your washer after the cycle is over. You need to do this once/twice year.
Posted on Oct 14, 2009
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
How to fix a front load kenmore washer that won't spin?
Look under the machine
There may be a service & troubleshooting
manual in a bag, taped inside it
Aug 10, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
Whirlpool duet wfw9450wr00
Michael, I too am looking for the same as you for my Whirlpool 8.5kg WFE1485BD. Similar machine as yours but newer. I need the schematic diagram to see how the door interlock switch works. Your problem sounds like that as well, have you tried manually working the switch with door open and checking with an ohmmeter? Does your machine give a door open warning light? I have pulled my door switch out and disassembled it but can't work out which contacts get switched. Please email me if you find a service schematic and I will do the same: steelwheels7@gmail.com
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
I have the front loading duet washer. The code F
F2 indicates a long drain usually caused by blockage in the filter, remove and clean out filter.
Also Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
If the above does not correct the problem, replace the pump
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Have a whirlpool duet front loading washer. Recently bought a new house, only way to access basement is up 5 steps on side of house to landing with railing.cannot turn machine on landing so door is facing...
This may or may not be helpful but please see the following Whirlpool installation and service manual for the Duet Sport washer.
It has a number of sections on accessing components and you may be able to determine how to take the front off.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Following is the Whirlpool service manual for two other models of the Duet washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
