Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Ink cartridge problem
Lcd screen says ' remove and check color cartridge. I've done that it looks fine but the printer refuses to print.
  • kb16_kb16 Jan 20, 2009
    Thankyou so much, I never thought of that!
  • 2,120 Answers
Replace it.
Posted on Jan 19, 2009
Does not print evenly. Some lines are very faint. Have done calibration and cleaned print head several times. Prints from internet and e-mails okay. But does print from Simply Accounting, tax software...
Welcome to FixYa.
Since you have already performed calibration and cleaned the printhead, kindly verify that the ink cartridges are not damaged and are completely seated in the printhead:
1. Lift the printer access door, then remove the ink cartridges from the printhead.
2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
3. Verify that the KODAK Ink Cartridges have not been refilled.
4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
6. Close the printer access door.
7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
8.Reprint the original picture or document that had the quality problem.
Hope this helps. Thanks for using FixYa.
Dec 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Greetings, I have a Canon Pixma M610 and this problem just started happening. Everytime I replace an ink cartridge, the new ink color doesn't print AT ALL until I run a "deep clean". Then,...
Try removing all ink cartridges and printhead from the printer. Then, look inside the printer with a flashlight. Look into the right side of the printer and see if there is lots of ink gunk. Remove if any and try not to leave ink gunk on other printer parts. Turn printer off when removing ink gunk. Then after you are done cleaning, turn printer on and wait for it to command you to insert printhead. Do that and close cover. Then, insert cartridges when printer asks for them. Hope that helps. -Alex
303Electronics eBay Stores
Jun 07, 2017 | Canon PIXMA MP610 InkJet Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Printing Problem
    Look for ink clogged on the printer head. Run cleaning or deep cleaning after installing the new cartridge before printing. Take nozzle check print.
    Apr 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
    Color majenta not printing
    We've encountered several problems like this and we end-up replacing the printer head especially separate printer head technology from ink-cartridge(s). Cleaning well do in most cases and original ink cartridges is always better:) and cleaning of nozzle should be done three times only for it may consume whole ink cartridge half empty. For the ink-cartridge with printer head builted-in the problem with missing color most likely on the contacts between the cartridge and tray. Please wipe the contact points gently with dry cloth or cotton buds. Try to check if the contact points were not rotten or corroded with dried inks. Have a nice day.
    Best regards,
    Rosener Guyano
    Feb 02, 2008 | HP PSC 1315 All-In-One InkJet Printer
    HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
    82 people viewed this question
    Ben Johnson
