Question about Proform XP 580 Trainer Treadmill
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
    Problem Solver:
  • 9 Answers
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Posted on Feb 06, 2013
  • Jay Cottingham Aug 13, 2013
    Any comment on a clicking sound when I start it?
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
ercupa190
  • 12223 Answers
SOURCE: trying to remove cover for Proform Sport 1000. $
You must be shure is screws are completely removed. Take some flaslights and see carefully if there are one.
After you can take our the cover easy.
sincerely.
Posted on Nov 28, 2011
SOURCE: Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
Posted on May 06, 2012
sureshreddy8
SOURCE: can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Posted on Nov 20, 2012
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Apr 04, 2013 | Proform XP 580 Trainer Treadmill
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Jan 04, 2013 | Proform XP 580 Trainer Treadmill
Can't get my proform xp 580 trainer treadmill out the door
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
I lost my key, is there anyway to start otherwise?
I can suggest a way to make the machine work without the key. If you remove the control panel cover you will see where the key switch is located. If you have a simple toggle switch you can remove the wires from the key switch and attach them to the toggle switch. then mount the switch in a position where you can easily turn it on and off. That is how I fixed mine.
Sep 30, 2012 | Proform XP 580 Trainer Treadmill
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
Jun 08, 2012 | Proform XP 580 Trainer Treadmill
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
My proform 580 runs for 1/2 second, shuts of, and resets and will repeat this as many times that you push the start button
HI,
Your treadmill have problem with the motor control board. The motor control IGBT is faulty thats why its stars at high speed and shuts off immediately by sensing over current drain. The solution is replacing the motor control board or replacing the IGBT on the motor control board. To replace the IGBT you should have a through knowledge in electronics. If you need any more assistance feel free to contact me through FixYa.
AJIN
Jan 19, 2012 | Proform XP 580 Trainer Treadmill
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
My Pro Form 580 XP slows down suddenly while on, and speeds up again almost making me fall off of it. Anyone know why this could happen? The manual is no help.
If you have not ever lubricated the running deck then I suggest doing so . What happens is that the lack of lubrication will tend to make the belt drag thus slowing down the belt making the motor control board to try to compensate the drag.
Apr 21, 2010 | Proform Crosswalk 500 Treadmill
Proform XP 580 Trainer Treadmill Logo
145 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
