Infocus screenplay 5700 I've had this product for
Infocus screenplay 5700 I've had this product for about 8 years now, all the sudden it doesn't turn on or respond in anyway when I click the power button, its plugged in but it won't respond
  • 13 Answers
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
Posted on Jan 09, 2013
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: InFocus ScreenPlay 5700, ceiling mount,
Most probable cause is a faulty power supply. The capacitors inside tend to overheat and burn out. They can be tested with ohmmeter for 25-30 ohms if you can get power supply open. Most people change entire supply. You can test power from supply to main circuit board with a voltmeter.
If you have a fuse, check to see if it is good. It will probably be next to power supply.
Last possible cause could be faulty control board usually due to faulty capacitors or resistors.
Posted on Oct 25, 2009
projdoc
  • 2237 Answers
SOURCE: its an Infocus screenplay 5700 projector.it is not powering up
replacing the main board.
Posted on Jan 27, 2010
tech4allmen
  • 666 Answers
SOURCE: My Infocus 5700 won't power
We can fix this. I believe you are handy enough to fix the power supply of this masterpiece.
I had 100% the same problem and finally figured it out. The problem is with one of the capacitors, and after lots of trial and error, and asking for advice, here it is: The capacitor is "C16" - a small blue electrolytic - 100uf 16v. It is in the center of the power supply board partially hidden by a black heat sink and the large silver chunk of metal.
Swapped for a 25v 100uf I had lying around and she works like a charm now.
Here's how it looked like on mine:
images?q=tbn:and9gcte64-3vvp7h6vtswd6pxijyyxdvcyifqgbtov0jpszkmueqklupg
Posted on Aug 24, 2011
SOURCE: InFocus ScreenPlay 5000 projector won't power on,orange LED
I was wondering if you have found what was the culprit?
Posted on Oct 25, 2011
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
Need Manoal
I have the manual with me. If you can give your email address then I'll sent the manual of InFocus ScreenPlay 5700 to that email address. Or you can down load the manual from the following link.
http://www.retrevo.com/support/InFocus-SP5700-Projectors-manual/id/1081ag706/t/2/
OK
Oct 10, 2011 | InFocus ScreenPlay 5700 Multimedia...
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700, ceiling mount, installed new 4 - 5 years ago, was working fine, now won't turn on. Gave me a high-speed flicker on the power button, but now nothing, even when plugged into a...
Oct 25, 2009 | InFocus ScreenPlay 5700 Multimedia...
Ful size image not transfering 4rm laptop 2 screen thru projector
image resolution is not syncing up. reset the settings to factory default, then hook up the laptop and press auto image. if it still doesn't work, you may need to change the resolution on your laptop.
Apr 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Screenplay 5700
Because these units have dangerous high voltages inside, there are a number of safety interlocks throughout. Take out the lamp and reseat it. Also, make sure that the access door is installed correctly and securely. Both have interlocks that will prevent a poiwer up is not installed correctly.
If this is not the case for you, please update this and we'll look for other causes.
Thanks,
Dan
Jan 05, 2009 | InFocus ScreenPlay 5700 Multimedia...
Lamp won't stay lit
I've got the same problem, I'm wondering if it has to do with some sort of auto shut off kicking in due to overheating or something, I was gonna try replacing the fan to see if it's something to do with that
Jul 07, 2008 | InFocus ScreenPlay 5700 Multimedia...
Problem with projection Infocus 5700
the light tunnel has collapsed and part of it is blocking the image. find an infocus service center to have them fix it because they don't sell the part.
Oct 27, 2007 | InFocus ScreenPlay 5700 Multimedia...
jasbo
jasbo
