Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Correct position of beater bar on a Dyson DC14?
Hi, We are trying to troubleshoot a loud rattling noise that is heard when we use it on carpet.  It sounds like the beater bar is hitting on something. We need diagrams or photos to show us the correct position to seat the beater bar. Jen
  • 3 more comments
  • Anonymous Jan 19, 2009
    I had the same problem, so I took it back and got a new one. The New one does the same thing. The beater bar doesn't hit anything, sounds like the drive skips soon as it hits the carpet. I think it is a safety feature to save the belt. My carpet is a burber, so there shouldn't be any resistants.
    Maybe to much power,or spins to fast and as soon as there is any pressure on the beater bar, it skips...
  • dinacorona Feb 03, 2009
    loud noise i think the belt is in wrong place
  • irishblend58 Feb 08, 2009
    My DC 14 has the same problem, I cleaned all the hair from the brush and belt drive but after awhile it starts again. I have to turn it off and on to stop the noise several times. Is this a design flaw and is there a fix for it? I am very handy and can replace the clutch but others stated that it happens even after the repair. Any ideas?
  • polar_bear_6 Apr 23, 2009
    my beater brush skips and sounds like a screeching noise - the end caps are loose on my brush --- so i think that the bearings inside are freezing up as they are not aligned from the wobble on the end cap which should be closed with no gaps
  • Anonymous May 08, 2009
    Same problem
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Posted on Mar 02, 2012
  • cindy p Mar 17, 2013
    thanks for the info...i bought a used Dyson DC 14 animal for 430! The brush roll wouldn't spin and it made a horrible loud noise when i tried to use it on the carpet adjustment. I ordered a new clutch and replaced it and it didn't help. I only paid $20 bucks for the new clutch on ebay so I wasn't too disappointed that it wasn't the problem. I then read your solution and removed both ends, cleaned the gunk out of them and sprayed with WD-40. Worked like a charm! I needed this dyson for my cleaning service (I have the same one at home and love it). I will be returning the new clutch and enjoying my $30 dyson:)
  • 389 Answers
Not exactly a solution, but more of an explanation. The noise is caused by a ratchet device that's designed to protect the belt if the brush roller becomes blocked. It's a bit like a clutch that slips when resistance on the brush gets too great. The noise will occur if there's a solid blockage, of course, but it will also occur whenever the machine senses excessive resistance. This may happen on carpets with really thick pile, but can also happen if the carpet is loosely fitted and can be sucked up tight to the roller by the force of the vacuum.
Small consolation, but the problem should lessen as the brush wears. Meanwhile, if all else fails, switch the brush off (hard floors mode) while vacuuming the problem carpet(s).
Posted on Feb 10, 2009
I've had the same problem off and on with my DC14, (not the animal version, but it's probably the same), for several years.  Typically by cutting off all of the hair on the brush, the brush has less resistance and will spin fine.  But this time, not the case.  I messed with it for an hour with no positive result, but I kept noticing that the screw piece (of the plate that keeps the brush bar in place), on the brush side, wasn't easily sliding into the screwing position.  Turns out, that the brush bar was ever so slightly out of place.  The half circular "setting" in the main housing where the brush bar and belt rest, were not lined up right with the brush bar.  With the belt still attached, I pulled the brush bar up slightly and slid it over a little so that the two side walls that keep the belt isolated on the bar, were returned to the outside position of the "setting" on the housing.
Posted on May 08, 2009
  • 1 more comment
  • jmni Mar 12, 2011
    I tried the same thing after reading your comment. The housing wall was bent and worn and was sitting outside the brush bar rim. I lifted the brush and pushed the bent plastic back inside the brush bar rim.It will probably happen again until I get a new housing.
  • Lyn Smith Dec 12, 2011
    Thank you switchback4 - it took a while to figure out what you meant but after some studying of the belt housing, it clicked! Now my Dyson DC14 is humming as good as new!
  • jasonbl1
    jasonbl1 Mar 18, 2012
    Did you add some form of lubrication to the ends of the beater bar? The reason i ask is, i believe the noise comes from the plastics rubbing together.
The explination does explain what is happening and I has gone to attachments or no brush on the throw rugs on the hard wood floors. I do think it is a design flaw with this model.
Posted on Feb 12, 2009
I have the same problem. My dyson dc14 makes a horrible noise when in the carpet position. Doesn't matter what kind of carpet. It stops when I bump the vac into a wall a little. Then back to the horrible noise. I have cleaned the brush and that doesn't help at all. Tried to reposition the beater bar brush and that doesn't work either. I think whoever posted that it's a design flaw was right. I guess we are screwed and need to purchase another?
Posted on Apr 29, 2010
Replaced clutch assembly, and new beater bar. loud noise coming from beater bar I think. how to take off ends of brush roller
Hi, it's Allan at Dyson.
We are unable to provide support to carry out a home-repair and would encourage you to contact Dyson directly to troubleshoot the effect you are experiencing.
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Many thanks,
Jan 25, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson DC14 Animal has begun to make an awful squealing/screeching noise. The beater bar is functioning well and there does not seem to be a loss in suction. The nasty sound happens with and with o
Hi there, it's Jack at Dyson.
An unusual noise like this can often be caused by something simple, like a part or a seal slightly out of position. I appreciate you've checked your DC14 thoroughly for issues, but we're usually able to diagnose the cause most effectively by listening to the machine over the phone.
When you have your DC14 easily to hand, I would encourage you to give the Dyson Customer Helpline a call to speak with our experts. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 15, 2015 | Dyson DC14 Animal Bagless Upright Cyclonic...
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar will not turn
Hi its Darran at Dyson.
Make sure that the brush control dial on the cleaner head is in the correct position for use on carpets. It should be in the centre position when in the upright mode and then when the head is released into the cleaning mode, the dial should move forward to the on position.
If you need any further help, please call us on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Dyson Customer Liaison
Apr 11, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in:
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
Aug 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
Feb 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suden loud noise when vacuming carpet
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
2,289 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
