Question about Maytag Dishwashers
Not draining completly
Serial # F-15205190 type 575-0 mod MD8TT53AWW4
2 Suggested Answers
  • 20 Answers
SOURCE: Kenmore model 665.17609300 type
Check your air gap on your drain. It should be located on or around your sink. Sometimes food and other trash will stop it up and will not let your dish washer drain. The cap should unscrew off .Good Luck.
Posted on Aug 13, 2009
User manual for Kenmore dish washer Mod#665.13842K601 Type 575-0
You can download th manual for free at the following Kenmore Support link
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0608085.pdf
Sep 09, 2012 | Kenmore Dishwashers
Dishwasher will not drain out. Is it a clogged drain, bad pump or something else. Model # DU1015XTXS2, Serial # F05301668 and the Type # 575-1. Where is the drain plug located? I have not used this...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jul 05, 2011 | Whirlpool Dishwashers
The freezer has been beeping about every 30 seconds for the past few years and I am going crazy. How can I fix it?
along as the freezer is workin fine then you can do this:
sorry if i am not accurate but you did not provide a complete model number so i dont have any diagram to follow
if this was my freezer and i would disconnect the wires going to the beeping sound. i thought of that too of course. if you send me a complete mod. # then i will give detail way to do this
hope this was helpful
Apr 02, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My whirlpool dishwasher is not getting any water to it. it goes thru the cycles,but no water.it is about 6yrs old..model#GU1200XTKQO serial#FL3716278 type 575-0
sounds like a bad water valve you can disconnect wires ohms it out with a meter and see if its good or not . your looking for continuity. go to searspartsdirect .ocm to see price for part and they will ship
Mar 03, 2010 | Whirlpool Dishwashers
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
Kenmore model 665.17609300 type 575-0 Dishwasher will not drain. Float valve and drain solenoid ohm out correctly. Drain hose is clear. Suggestions?
Aug 13, 2009 | Kenmore Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
