Question about Olympus VR-340 16MP Silver Digital Camera
How do you turn off gridlines/settings bar on the screen?
I would like to turn off the gridlines/settings bar on the screen and I can't find the setting.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
See page 19 of this manual.
Posted on Jan 05, 2013
How do I copy an excel sheet into word showing grid lines
Show or hide drawing gridlines Drawing gridlines appear only in Print Layout view.
  • On the View tab, in the Show/Hide group, select the Gridlines check box. " alt="Word Ribbon Image">
Sep 29, 2014 | Dell Computers & Internet
Lost bottom bar w/ menu.
This is a camera or something else? Either way, what make and model?
Jul 24, 2013 | Cameras
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Looks like grid lines on screen
Sounds like you have either a bad main pcb, or a bad LCD control pcb. Either way it is a board replacement.
Apr 08, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Can't print line
Depending on what version of Excel you are using try the following:
The lines are called gridlines
  1. Click the worksheet.
  2. On the File menu, click Page Setup, and then click the Sheet tab.
  3. Select the Gridlines check box.
Note Large worksheets print faster if you do not select the Gridlines check box.
Please rate this solution...Thanks
Mar 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Dell P1500 Printer does not print Mriscroft Calendar gridlines
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Dell P1500 Laser Printer
IBM Thinkpad 2652 has horizontal and vertical gridlines on screen
Try to remove your Memory modules and clean the contacts with a pencil eraser. Makes sure to clean both sides of the memory contacts.
Nov 21, 2008 | IBM ThinkPad A31 Notebook
Olympus VR-340 16MP Silver Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
