Leaks water onto floor while in use
Growling sound while agitater is working
  • 90 Answers
It sounds like a water hose is leaking or has a split in it. Check the water in-take hoses on the back of the washing macine, to see if its leaking or split. If they are leaking, unscrew the hose and check or replace the rubber washer, thats in the brass screw-in part. Next, unplug the washer power cord, unscrew the intake water hoses that are in the back and turn the washer on it's side and check the water hoses underneath the washer. They may be loose or split. Any hardware store should have these hoses in stock, like Lowes or Home Dept, or your local "Do it center".
Posted on Jan 19, 2009
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Apr 22, 2008 | Refrigerators
Water puddles leaking our of overflow pipe onto floor
sounds like your pressure relief is leaking. Make sure your home water pressure isn't abnormally high (above 80 psi). As long as your water pressure is fine, you should replace the pressure relief.
May 25, 2010 | Noritz 6.3 Gallon Residential Tankless...
The water feeds into the unit with no outside leaks but when it gets onto the unit it leaks out into the toilet and on top of it and tehn leaks onto the floor.. The water used to shut off once the unit had...
IIt sounds like you need a new fill float assembly. First replsce the shut off valve at the wall if it's broken. The fill valve is easy to vhage. Set shut off point 5/8" from top of overflow drain tube. -Good Luck, Ned-
May 21, 2010 | NRS Brondell Swash 600 Bidet Elongated...
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Water leakage
its possible when you are doing a big load it demand more water so the water goes true the agitater seal which is located under that white agitater the seal is between the two shaft thanks from gilles
Mar 14, 2009 | Washing Machines
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
