Question about Franklin 4.0 cu. ft. Refrigerator / Freezer
What is the coldest setting for the Franklin 4.0 Cu. Ft. Regrigerator / Freezer
GARF19XXYK00, doesn't cool properly, 36 - 40 deg. F on coldest setting. A & E just replaced the bi-metal , defrost part, thinking the defrost keeps it too warm, but guess what, still the sam
There is a TSB on this (TSB) = Technical Service bulletin. You need a service company to order part number W10599551 and put it on. This will fix the problem.
Feb 01, 2013 | Whirlpool GARF19XXYK 19.0 cu. ft....
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
What setting is the coldest on refrigerator? it goes 1-6
#6 is the coolest on the fridge, with the #1 being least coldest to #6 being the coldest setting.
Apr 04, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
From 0 to 9 what is the coldest setting for my Magic chef freezer?
9 is usuly the coldes setting on the freezer. It needs 24 hrs to get to the setting that you put it on.
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Magic Chef 19.6 cu. ft. / 555 liter...
What are the temperture control setting 1 2 3 4 5 6 7 temperature
7 being the coldest then going down from there usuallly you keep it around 5
Aug 18, 2010 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezer work's excellent,, but fridge part is getting warmer every day now and will soon not be able to keep food cool. Have freezer set at D and E is coldest.... have frige set at 9 coldest setting but...
The freezer plates are the first to get the dwindling freon an dthat will remain the coldest. Find the leak and have it repaired (not just refilled or you will be here again in a few days!
JOAT
Jun 28, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Franklin 4.0 cu. ft. Refrigerator / Freezer Logo
24 people viewed this question
Top Franklin Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Refrigerator Expert? Answer questions, earn points and help others
