Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
There is sound but no picture.
    New Friend:
Try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Posted on Jan 05, 2013
Testimonial: "That worked thanks!!"
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
SOURCE: Sony KDF-46E2000 hd picture problems
MY Sony (same model) has OUTstanding picture resolution and quality., I never have blockiness on any of the sports channels. I would say, give Comcast a call and complain about their signal.. they have a tech come over for free diagnostics on your wiring..
Posted on Nov 11, 2008
  • 108 Answers
SOURCE: ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Posted on Jan 08, 2009
  • 13 Answers
SOURCE: I have a Sony Grand Wega KDF-55E2000, I just
I have the same issue, and it appears to be the optical block. Sony has extended the warranty to replace these through June 2010.
http://esupport.sony.com/perl/news-item.pl?news_id=293&mdl=KDF55E2000
Posted on Mar 27, 2009
SOURCE: My Sony Bravia KDF-E50A12U has a ghost effect when
Ok, firstly, disclaimer.
This "solution" utilises a "service" menu, that only trained engineers should use. You are not one, you are an "end user". biggrin.gif So am I, but I paid attention. wink.gif
Use of this information is entirely at your own risk, you mess up your telly, it's your own silly fault. Don't go messing with stuff in there you don't know about.
Ok.
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11". (it's on the next "page", keeping scrolling down the menu)
Press the menu button to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Apr 01, 2010
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Hdmi inputs select
This is a 720P TV, please try set up your Samsung DVD play video out put format to 720P, then try it again.
Aug 15, 2017 | Sony KDF-50E2000 50" HDTV
I have a sony bravia bx421 when i connect my ps3 to it using hmdi it says unsupported signal please check device output, please help mee.. i tried everything such resetting the video, changing the output...
Hey jhoff, you're a ******* ******. I'm having this problem right now, it only just started, my PS3 worked for a year on my Bravia before pulling this. Apples to oranges my ***. Go **** yourself, *******.
Nov 15, 2011 | Televison & Video
I hooked up my tv,a sony bravia bx3 to my laptop using an hdmi cable which i disconnected from myps3 while it was still on,it worked perfect.suddenly the ps3 switched off.I re-connected my ps3 to the tv...
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved. If you still get problem message me cause its technically bad.
Dec 15, 2010 | Video Game Consoles & Games
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Why my hdmi cable keeps saying unsupported signal. check your device output
use a normal cable to connect to you tv and check the resolution that the hdmi is trying to output. if it wont display with the normal one then you will have to reset the video output system.
http://www.tipstrs.com/tip/1888/Reset-your-PS3-video-settings
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
Everything is connected but when i turn on the ps3 the tv says unsupported signal check your device output
make sure your hook-ups are connected correctly and if so could be a high def setting or componet setting inside you system.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
Jul 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
406 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
