Question about Philips 60P8341 60" Rear Projection Television
Tv reacts very slow
I have a philips model 60p8341 tv. If you turn off the tv, it will not remember the color settings. Also the processor doesn't work properly. If you press a button on the tv or the remote, it takes the tv a few seconds to react.( press volumne + key, few seconds later the volumne appears on the screen, few seconds later the number goes up one, few seconds later goes up one, etc?) Same reaction with changing channel or menu functions. Any help would be greatly appreciated.
  • 40 Answers
The problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Posted on Jun 27, 2007
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
I have a Phillips rear proj. 60pp9202/17f with a color problem
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Jul 12, 2009 | Philips 60P8341 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Aug 25, 2007 | Philips 60P8341 60" Rear Projection...
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
