Question about Lionel Trains Classic Freight Train Set
Wire diagram for railsounds box car lionel 6-19229 frisco
Need to re wire it was partialy dis conected my big question is where to run the power yellow middle track wires and the yellow from the motion sensor
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: need wire and hook-up diagrams for Lionel train
http://cs.trains.com/TRCCS/forums/t/195035.aspx
Posted on Aug 01, 2011
  • 34 Answers
SOURCE: CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Posted on Sep 05, 2011
  • 34 Answers
SOURCE: How to wire a Lionel block signa lwith insulated
Only one outside rail has to be insulated from other sections. A hot wire goes to the signal block. The other wire from the signal block goes to the section of track with the insulated outside rail. When the train passes over the section of track with the isolated rail, a connection is made to the power supply common through the wheel axel. The other wire from the aux supply (common) is connected to the same common as the supply powering the rails. Power the block signal from an aux supply not rail power.
Posted on Oct 05, 2011
technowee362
SOURCE: I have a Lionel ZW transformer older version
Just wanted to add a note to this problem you are having....Question is this...How big is the train layout and how many power clips do you have on the track??
Reason is being if you only have one power clip for the whole track, you will notice a decrease (slowdown) of the train in certain area(s) so i would recommend adding another power clip or two to your layout, also If you are using old regular O track, make sure you have the metal pins in all 3 railsHope this helps
Posted on Apr 06, 2012
Lionel 2330 wiring diagram
Request the wiring diagram directly from Lionel.
Feb 26, 2018 | Crafts & Hobbies
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
Need diagram for hooking up #252 Lionel Crossing Gate
Here's a link to the Service Manual to the 252 Crossing gate.
http://www.lionel.com/media/servicedocuments/71-2714-250.pdf
Dec 31, 2012 | Lionel O 27 252 Auto Crossing Gate
Parked my car and when i went to drive home it wouldn't start , nothing totally dead. wouldn't start with a boost.
This happened to my sisters cavalier about a year ago. What you want to do is on the + side of the battery follow the red wire lead it should split in to 2 different wires a big wire and a small wire. The big wire should go down to starter and the small wire runs to a fuze box on the drivers side fender well behind the battery. Where the small wire conects to the fuzebox check that conection. On my sisters car it was broken there and would not allow power to get to the PCM, ECM and nothing worked. I hope this helps you out. If you have any questions let me no. goodluck, kyle
Apr 18, 2011 | 2001 Chevrolet Cavalier
I recently purchased a Dash 9-44 CW Diesel locomotive. It has on the label of the box "Command Equipped" - "Towercom TM" - "Crewtalk TM" - "Railsounds TM". My...
I'm not familiar with the Dash 9-44 CW but it may be that the sound and smoke switches are turned off. You will probably find these under a removable cover on top of the locomotive or under it, usually near the cab. Check your instructions or go to Lionel.com and click on support. Instructions and manuals can be found here.
Apr 29, 2017 | Lionel Toys
I have an '03 f350 and the trans fluid guage went hot and tow haul started blinking
check your trans fluide oil for a burnt smell
if so replace ---mercon sp only in power shift trans
anything else will cause damaged
tow haul light fashing = trasmission code
need to scan probably faulty sensor chaff wire
dirty conection /partialy unplug junction
burnt fuse
Dec 28, 2010 | 2004 Ford F350
Lionel Trains Classic Freight Train Set Logo
866 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
