Need diagram for 2008 phillips dvd mod. dvp 1120/37 to hook-up to tv
Lost wire cable info to my tv
  • 142 Answers
SOURCE: dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Posted on Mar 10, 2008
SOURCE: REMOTE CODE FOR PHILLIPS DVD DVP3140
I don't know if this will work for you since your Philips universal remote is a different model. I tried all the codes listed for a Philips DVD player in my Philips SRU3004/27 universal remote manual. Two of them partially worked (wouldn't let me scan forwards and backwards). The last one they listed did work, code 1214. I suggest trying all the codes in the handout that comes with the remote for Philips DVD players. Make sure each number you press registers (the indicator light on the remote will blink). Philps also lists these codes on their web site. Good luck!
Posted on Feb 01, 2009
SOURCE: My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Posted on Feb 25, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
SOURCE: I have a Phillips DVD player model DVP 3962/37 password
the factory password for my dvd player is 136900 but i too have this problem. i do not know how to disable the password
Posted on Mar 01, 2010
How do I connect a Sony DVD DVP-SR210P to a Scientific Atlanta Explorer 4240 HDC and a Sylvania TV C320SLX?
I am not sure you can connect your DVD player to your cable box. You should be able to connect both your cable box and DVD player to your TV set with two HDMI cables. This link is a pdf_usecares file of the TV manual that shows how to hook up your dad and cable box.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0902617.pdf
Hope this helps.
Bob
Jan 04, 2015 | Sony DVP-SR210P Progressive Scan DVD...
I have lost colour in my DVD Player, It's showing black and white illustration. How to fix it.
U hook it up wih a AV RCA R,Y,W cable change the cable or u used a HDMI cable,change another HDMI cable to another tv HDMI hub.
Jan 29, 2011 | Sony DVP-NS508P/S DVD Player
I need to hook up the dvd player to my new Sony
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
Jul 19, 2010 | Sony DVP-NS50P DVD Player
How does one hook up a DVD/CD to a digatal TV
well since you have a digital tv (you have all sorts of jacks in the back or side panel)...your dvd has 3 (rca) cable wires (yellow/red/white)..we need to plug these three wires into the back of tv where its video in (depending on your set it might say dvd/digital in or whatever)...once you have did this in order to see the dvd using the remote switch the source (between tv/av1/av2 or cable)..remember your tv stays on ch 3....to get back to your regular tv again using the remote for the tv switch the source to tv/cable''
feel free to rate the help
Jul 03, 2010 | Sony DVP-NS710H/B DVD Player
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
No video/audio on tv when powered up and running
drew a diagram of the back of each component & wires/cables and emailed it to my grandson,
The video wires in the VCR were placed out instead of in. That solved the problem Thanks.
Feb 14, 2009 | Sony DVP-S360D DVD Player
Phillips dvd player
i need to figure out how to burn a dvd with my phillips hdmi recorder.
Sep 13, 2008 | Televison & Video
Phillips DVD player, No sound
Swap out the red/whites - loud hum means something isn't hooked up right
Make sure a/v cables going OUT from dvp and IN to tv
Feb 19, 2008 | Philips DVD 622 DVD Player
Feb 02, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
