Question about HP dv9620us Notebook
Starts and stops
The computer tries to powerup but then after about 5 seconds it shuts down, then it tries again. It will keep doing this. All the LED's light up but it's never on long enough for the screen to come on.
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Assuming you are Windows based?
First disconnect all non essential devices, cords, internet connection, etc. Try rebooting normal. If that works try adding one thing at a time back to your computer, rebooting each time to test. If the initial test fails try rebooting in Safe mode.
If windows PC based, try booting to safe mode by tapping F8 as soon as the power is activated. Continue tapping until a menu appears....it should have Start in Safe Mode as a selection. If not find out the proper Start in Safe Mode for your OS. Safe mode operates your computer with the basics. If you can start in Safe Mode you might have a software issue. If you loaded something prior to failure, attempt to uninstall that software, or "Restore" your computer to a previous time.
If attempting to start in Safe Mode fails, attempt to start from a CD/DVD drive with a Windows Recovery disk or your original copy of the Windows program in your drive, (Normally your computer is set to first try downloading Windows from your Hard Drive. You have to go into you "boot menu" to change these directions. It varies by OS version but in most cases start tapping F12 on initial power up until you get a menu. You mouse is not usable. You must arrow up/down etc to move around. Depending on what you see concerning the "primary" drive or list of sequence of drives, you will more than likely see Hard drive or SATA. Write down what you have before changing anything. Change your primary boot up drive to be your CD/DVD drive and save your changes. Power off, insert your windows CD in your CD/DVD and power on. If windows boots up from your CD you probably have a bad or corrupted hard drive, or something in the associated circuitry, wiring? REMEMBER YOU HAVE CHANGED YOU BOOT MENU TO CD/DVD. YOU MIGHT NEED TO CHANGE IT BACK TO SATA OR YOUR HD DESIGNATION DEPENDING ON WHAT YOU DECIDE TO DO. It might be as easy as going to Fry's or another electronics place and purchasing a similar hard drive. Fairly easy to unplug, unscrew and replace. Watch for a "Master" "Slave" connector on the drive itself. Some of them had a little jumper. It has to be placed the same on your new drive. Of course if you replace the HD you will need to reload Windows first .(make sure you have a key code for windows) Then all your other drivers, and software. You will not have any of your old files unless you are able to retrieve them from the old drive. That recovery process is something for someone with advanced technical skills....if it is even possible. If you don't possess the skills to remove and replace the HD, pay someone to do it. They will probably also reload any software at the same time for nearly the same price.
Posted on Jan 05, 2013
Testimonial: "While I ended up fixing my laptop in a different manner, the answer was very thorough and much appreciated."
  • Shirley McManus Jan 07, 2013
    Thank you for your suggestions. I ended up taking the entire thing apart, cleaning it, checking the components, and then put it back together while making sure all the connections were stable. It worked, and started, but there were hard drive errors. I used my Windows 7 disc and wiped the drive and did a complete clean install. Works like it used to! Thank you again.
jamesmac
  • 71 Answers
SOURCE: Will not start up
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Posted on Sep 09, 2008
  • 477 Answers
SOURCE: I have a HP Pavilion tx 1000. Blank screen, LED lights on.
Hello, seems like your sleep mode doesent work as it should. Try to download all windows updates and look for a fix on microsoft sites.
But the best solution is to inactive the sleep mode setting and use the Hibernate options(if you want a fast start) but I suggest that you turn off windows with shutdown, its the safest and best way to have your computer to work properly.
To inactivate sleep mode.
windows xp
go control panel and power options
Change the system standby to never.
also choose power schemes battery, and change the system standby to never.
also the harddisk to never.
This should solve your problem.
To activate Hibernate you need to click on hibernate tab and bock the square.
hibernate= saves all your work to harddrive to restart your computer where you left off.
sleep mode= saves your work to RAM memory=takes a little bit energy.
Posted on Sep 04, 2009
Testimonial: "already, my computer is not freezing:) thanks for the tip."
PROTOtype85
  • 5 Answers
SOURCE: The computer starts up and then shuts down, then
First things to establish, if you are running from battery whether the laptop is charged, if you are running from AC whether the cable works properly. If both of these are ok, have you made any hardware changes recently? If so, check that the are securley installed and if so then remove if possible. Failing that there may be a problem with the power supply to the motherboard, something you may be able to address if you have an intermediate understanding of internal components.
Posted on Nov 13, 2009
  • 48 Answers
SOURCE: Compaq V6305NR On pressing start button, then turns off & restart
Mostly it is due to the GMCH problem. If you can do chip level repairing, I can guide you. Please inform me if you can.
Posted on Feb 17, 2010
  • 3278 Answers
SOURCE: I'm sure this is a
Hello.
Could be a power issue.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on Jun 06, 2011
M'y kenmore dryer start for 15 seconde and stop for 60 seconde and start again and stop again.what si th? probl?me?
Most likely, the thermostat is bad and the heater is getting too hot. It shuts off to keep from catching fire, then cools down and works again.
Feb 19, 2017 | Kenmore Dryers
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
Zebra TLP 2844
I don't know if any errors with red blinks for the 2844, but the printer will blink red five times if you power it up with the button held. Is the button possibly stuck down?
Jul 07, 2015 | Zebra Office Equipment & Supplies
1997 Plymouth Breeze Engine keeps shutting off.
You need to do an OBD2 engine control module fault code test to see if the fault is recorded in the memory of the computer control module. Autozone and others do this testing for free.
Jun 24, 2017 | 1997 Plymouth Grand Voyager
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
HOW DO I REBOOT MY COMPUTER ?
Hold the power button down for over 5 seconds to hard-stop it. Then start it again.
Mar 11, 2011 | ZT Group Cisnet PC Desktop
Nothing on powerup.
Open it up again and find the wire you blew off.
Oct 25, 2009 | Toshiba Satellite X205-SLI1 Notebook
Computer shutsdown and restarts automatically
solution your problem
First you change powersupply if restrat problem is not solve then cheque RAM if restrat problem is not solve then cheque BIOS Battry And clear the BIOS & Go to BIOS load default setting Bios if restrat problem is not solve then install os if restrat problem is not solve then cheque mother board and restore the OS ok now will solve your problem
Yours
Pradip Sisodiya
Jun 08, 2008 | Computers & Internet
Power issue
plz check if there is any disc in the drive?
if not this time the system restart keep tapping on f 8
and go to safe mode type msconfig in run clk ok
new win will *** up go to startup tab down at bottom disable all
apply ok restart teh computer clk on the chk box dont show this mesg again once the computer will boot let me know if teh thing doesnt work
May 22, 2008 | Compaq Presario 700 470024-192 Notebook
HP dv9620us Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
