Question about SYMA Toys industrial SYMA S009 Micro Indoor Helicopter
How to find my potentiometer
Spinning on takeoff
    Problem Solver:
  • 21 Answers
It is on the hand controller the two buttons on top of the hand grips keep pressing the button until it stops spinning use whichever button left or right depending on the direction of the spin.
Kind regards, Julian
rccontrolfreak.co.uk
Posted on Dec 03, 2013
On Screen Takeoff 3.8.1.36
I NEED SERIAL NUMBER AND ACTIVATION CODE,PLANSWIFT / TAKEOFF LIVE /ON SCREEN TAKEOFF
Nov 24, 2013 | On Center Software On-Screen Takeoff
I have an Aiwa z650 3disc cd player,the disc spins a couple of times and then stops I'm told the potentiometer may need adjusting,I've taken the case of but can't find this thing
Not sure bout that ,,usally when it spins a few times and thats it,,motor wore out,,,put a disc in try as it stops spinning or right wen its fixon to start spinning given it a help spin,,i had that fix or getem goin,,,,also try tapping it ,,and hitting the side od the machine,,good luck,,
Dec 23, 2011 | Aiwa Audio Players & Recorders
Spin cycle not removing all water - seems like it used to do a much better job. Used to achieve maximum spin speed faster than it does now and there is also a low growling noise at the beginning of the...
This is a belt drive machine, it takes more power to spin than to wash if the belt is worn it could spin slower, do you smell any belt russery burnt smell?
Sep 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Spin cycle makes jet airplane takeoff noise. assume main bearing on spining tub is out. What part replaces this bearing? Diagrams do not mention bearing!
Bearings do exist but need a special puller to remove. If techs i n your area have it part numbers are 22002934 , 22003441 also needed is spacer 22002935 and seal kit 12002022 or else you need to order the whole outer basket
Jun 04, 2011 | Maytag Neptune MAH6500A Front Load Washer
The loudness knob has suddenly stopped working. The knob just spins, won't turn on the receiver at all. Any ideas?
The knobs are usually connected to a potentiometer; basically a variable resistor circuit with a long shaft that the knob attaches to. The knob could be secured to the shaft with a plastic grommet, which can be stripped. It could be attached by a small screw on the knob, and tightening that would fix it. Or, it's possible that the potentiometer itself broke, and would need to be replaced.
If the "pot" is broken, a repair shop should be able to fix it for less than $50. If you're handy with tools, you can take the 7100A apart; hopefully read the specs from the potentiometer; and buy a new one. Replacing it shouldn't take more than a few screwdrivers, some pliers, and a soldering iron...
Feb 06, 2011 | Sherwood 7100A Receiver
I cant get it from spinning in a circle
Hi Robert,
The helicopter has a trim screw with adjustment procedure being said on page 8 of the manual. You are probably aware of this but I wanted to mention it just in case it was overlooked.
You may have also noticed that the torque of the prop with the skids on a hard surface tend to turn the craft in one direction but if you get it in the air, it may very well spin in the opposite direction. What this means is that you want to do your trimming based how the craft responds in the air.
I should not say this but am going to anyway. What I did was to hold the craft with a light grip on the skids in one hand then jogged the remote with the other. You can feel the initial torque try to pull left but as the prop rpm increases, you may then feel it start to turn to the right. What I would do at this point was to stop and turn the potentiometer screw but just a little, about the same distance of the width of the screw slot. I repeated this four or five times and ended up with the craft setting level in my hand with the rpm being almost enough for takeoff.
The machine has a fairly powerful little motor so I dont think you can cure the way the torque upsets the craft upon takeoff. My best advice is to get it in the air quickly with the remote trim in the full opposite position of the spin. It will line out quickly once you get the rpm up.
Dec 27, 2010 | Jumbo RC JUMBO HELICOPTER
Shuttle 9094 r/c helicopter spinning on take-off
usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Dec 22, 2008 | Shuttle 9094 Emax Remote Control...
SYMA Toys industrial SYMA S009 Micro Indoor Helicopter Logo
110 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
