Question about House Brand Heating&Air Conditioning Booster Fan
Not heat on 1st and 2nd floor but basement is great
I have a baseboard water system and I got the air out of the baseboards and I clean them up but it did not work. It could be that the baseboars are to old. The ones in the basement are new.
    Problem Solver:
  • 7 Answers
I can help, but I need a little more info. What kind of boiler do you have, and is it gas, oil, or electric heated, and do you have an air seperator with an expansion tank on it. It basically sounds like you are not moving water through the system. The only to causes for this would be a bad circulator pump, or it is simply air locked. I would check out the circulator pump first. It will most likely be attached to the boiler, and will be in line on the main pipe coming out of the boiler. It is driven by electric, so check out the wiring, and electric supply going to it. There are many brands of these pumps out there. The most common are Taco, Garfundos, and Bell & Gossit. If the pump is pumping, then I would find the highest point of the system and bleed it from there. This can sometimes be a timely undertaking. Just because you are not getting any air out immediately, doesn't mean it isn't there. A good rule of thumb is to take out a gallon of water. If you don't get any air then, your probably good to go. Also remember to make sure your supply water valve is open to put that water back in. Let me know how you do...Rob
Posted on Dec 28, 2009
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
I am putting baseboard hot water heat in an older house that hase outlets in the way, is it alright to mount the baseboard above outlets . It would be about 12 inches.
Not sure that would pass code. But, you may want to check with the local building inspections dept in your area, before doing it. The other down side will be, the heat will start 12" of the floor rather than floor level. As you are aware, heat rises, so that would mean the lower 12" to the floor is going to remain cold. Want feel very good on bare feet that just jumped out of bed.
Feb 25, 2011 | Marley Electric Hydronic Baseboard Heater,...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
I want to install 240v baseboard htrs in a below ground basement.
you must really love your hydro co
those heaters are a huge draw on your bill
why not install radiant heat they are cheep now in compairison
the unit is a central mount run the line in a loop arround basement and conect all the heaters in drop lines off the main line small thermostat valve for each room to control heat
cost is more for unit but savings are greater too they now make a light duty units designed for your porpose
single direct electric heaters are pigs on the hydro bell if you have gas or electric it is cheeper to run a small boiler or heat on demand system
Aug 04, 2009 | Heating & Cooling
One zone not working; another is partly working
i would check my water pressure on boiler sounds like lack of pressure or air in system they can be related. if you have bleeder on baseboard try to bleed.
Feb 20, 2009 | Honeywell Programmable Thermostat Heater
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Baseboard heaters
measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
House Brand Heating&Air Conditioning Booster Fan Logo
77 people viewed this question
Top House Brand Dryers Experts
Are you a House Brand Dryer Expert? Answer questions, earn points and help others
