Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
Can't connect to the internet
I registered my cable modem (Motorola SurfBoard 5100) with my ISP this morning and after I connected the power supply, cable and ethernet cable, I still have no connectivity. The power light is on, but receiving is blinking. My ISP said that I need to set up an appointment for a service call, but I was trying to avoid that and get it hooked up today if possible. Please help.
  • 104 Answers
TRY RESETTING THE MODEM SWITCH OFF THE MODEM FOR 5 MIN THEN TURN BACK ON THE RECEIVING WILL BLINK THEN GO TO STEADY ON WHEN YOU ARE CONNECTED ALSO YOU CAN REPAIR THE CONNECTION BY LEFT CLICKING THE CONNECTION ICON ON YOUR COMPUTOR
Posted on Jan 19, 2009
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Motorola surfboard 5100 garden walled error
Sounds like your modem is in a provisional state. Walled garden is simply a tool to provision a modem..... a way that a cable or ADSL company uses to verify that the equipment is associated with a paying customer. Call your ISP if you are unable to access anything past that page via a browser. Chances are your provisioning record is lost, your modem has changed, there are too many devices connected directly to the modem, or there are other account issues such as nonpay status.
Before you call...
Check your modem connections, most companies will not allow two IP addresses to be issued to one piece of equipment (modem) without an extra fee, some companies will not allow two devices to be connected to a modem at all. If you have a device connected USB to the modem and another device connected through the ethernet port...disconnect one. I suggest going Ethernet and using a router if you wish to have more than one device connected to your modem.
Make sure the modem that worked yesterday is the one you are using today. If you've recently replaced your modem, you may need to call your cable company to register the new modem. One modem = one instance of service.
Check your bill due date. If your bill is past due, you may need to satisfy the past due balance before being allowed past the walled garden.
Sep 29, 2012 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My motorola SURFboard SB5101 has a on power light, a blinking recieve light, and an on PC/Activity light, with the other lights off. what is wrong with it?
The light pattern you have described indicates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register your modem on there network. So if you have not all ready completed that process you will most likely not have access.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Arris SURFboard SB5101 Cable Modem
Motorola modem light wont go past send
Aug 19, 2010 | Arris SURFboard SB5101 Cable Modem
I have a motorola SB5120 modem but no disc for it.How can I make it work?
With this type of modem no type of software will be required to establish a connection to your computer or router. However the modem will still need to be registered with your internet service provider. If you do not have the software to complete the registration process you will need to contact your ISP. The good news is that the registration of the modem should not take more than a few minutes and can be performed over the phone. After the registration has been completed connect the modem to your computer via a Ethernet cable. You may need to perform a hard reset of the modem at this time. To do this turn off your computer and unplug the power cable from your modem. Wait 2 minutes and reconnect the modems power cable. Give the modem another 2 to 5 minutes to reestablish the connection to your ISP. Power back on the computer and you should have internet access.
I hope the information above has helped in some way.
Aug 11, 2010 | Arris SURFboard SB5120 Modem
Cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
May 30, 2009 | Arris SURFboard® SB5101 Cable Modem
SB5101 Motorola Modem Disconnects Randomly
If all the lights go out I would assume you mean the power light as well. Couple of things I would look at:
Has your ISP replaced the modem including the power adapter?
Has your ISP verified there is no short on the incoming data cable? You could try to wiggle the incoming data cable to see if the lights go out. I would do the same on the power cable.
If it's not a mechanical fault (cables), verify that you have the correct and current drivers for your modem and operating system.
Good luck and thanks for using FixYa.
May 12, 2009 | Arris SURFboard® SB5101 Cable Modem
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
My modem is off
Modem and coaxial cable abnormally connect, or probably loosing power from internet. ask your local ISP
Jun 24, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
How to put mi moden to work directly
you need to register the modem MAC id to your ISP and do the regular physical connection (Co-axial cable to the modem ). it will work
Oct 03, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
323 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
