Acoustic Solutions CTVL26W3HD tv turns on with sound but no picture. Has flashing red light at back of tv on the circuit board
WebTeligent
  • 42 Answers
SOURCE: Acoustic Solutions TV
Try: http://www.viewpia.nl/html/downloads/viewpia_multilanguage_LCDmanual.pdf
Posted on Nov 09, 2007
  • 53 Answers
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Posted on Mar 20, 2009
BoiseLCD
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD www.boiselcd.com
Posted on Apr 23, 2010
SOURCE: acoustic solutions tv screen flashing coulour blue
Heya dude, iv got the exact telly as mentioned. Had this problem just recently. i tried everything, switching off power, unplugging everything. i was just about to start looking for a new telly when i tried using the remote.i pressed the menu button a few times,mabe this was a fluke or maybe it just sorts the problem out. It seems to me that this problem is a built in pixel fixer which somehow starts itself. Hope i help
Posted on Aug 09, 2010
SOURCE: Acoustic Solutions LCD26761HDF TV turned
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Posted on Nov 29, 2010
What to I do if my TV got wet on the power cord but I am getting picture and sound before it cuts off?
If the liquid got into the TV and onto the printed circuit board, there could be damage to the circuit board. The fact that the TV had a reaction to the liquid is not a good thing. If the TV is still wet inside the problem will remain. If you continue to turn the TV on if it is still wet you might cause more damage. I would wait until the liquid is gone or dry and try the TV again. If the TV was in the normal position to watch, the liquid should run off and dry in a few days.
Aug 20, 2015 | Samsung Televison & Video
I have a lcd acoustic solutions tv, the blue standby light is on and when I turn the tv on the white channel number comes up but the screen then goes black, all sound is working ect just no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jul 05, 2015 | Televison & Video
Flashing red light off and on button sound but no picture
If your TV has sound but no picture, start by making sure that all of the set-top box cables and cords are connected and the set-top box is turned on. Also check to see that the TV is set on the correct channel and that the DVD player is not on.
If the power light is flashing, it could be excessive or shorted voltage or that the capacitors are malfunctioning. In this case, replacement capacitors or a new power board is in order. Contact a professional for help.
If you hear a chirping sound, that is the shutdown circuit activating, indicating a problem with the power supply.
For more tips and tricks, check out No picture on TV for troubleshooting steps and solutions. I hope this helps!
Sep 20, 2012 | Toshiba 36A43 36" TV
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Acoustic solutions lcd 22''tv turn it on then it turns it self of
Acoustic Solutions 32 lcd hd Tv screen has green/blue contrast shadows all over the light images on the screen. I have tried changing all the picture setting to no avail.
Aug 22, 2009 | Televison & Video
Acoustic solutions TV
There is not a RF TV signal or the RF circuit is has a bad funtion, try to verify de antenna connection
Feb 03, 2008 | Audio Players & Recorders
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Jan 27, 2008 | Televison & Video
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
