Question about Whirlpool LEQ9858P Electric Dryer
Dryer won't tumble
Whirlpool model LEP 6848AW0 electric dryer, hear humming, heats up, doesn't tumble, was told it was the belt and was told its difficult to get to, was told entire drum had to be removed to check out the belt. Need to know if i'm getting ripped off or can I do this myself.
  • Whirlpool Master
  • 8,220 Answers
It is not hard to do at all. Start by yanking out the filter. Then remove those 2 phillips scews that hold down the top at the filter housing. Next use a putty knife to pop the top by pressing against the spring clips that hold the top down to the front. Next remove the 2 screws holding the front on. Raise up on the front to release the front from the case without breaking the el cheapo retainers. Once you have the front out your way get the drum out. Oil the wheels and idler using a high temp resistant quality turbine oil. Zoom spout oil is cheap and easy to find at any ace hardware. Rout the idler as pictured HERE using the whirlpool/kenmore pic. Piece of cake!
Posted on Jan 19, 2009
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
Dryer won't tumble, i only hear on/off switch humming.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 25, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Clean tough gas dryer
Probably, you are hearing the motor turning. The belt likely broke.
Dec 24, 2007 | Whirlpool GEQ9800P Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
