Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Installing WR55X10490 and there is no pin configuration for the connector
    Genius:
  • 1,669 Answers
Please contact the supplier of the part. THey should be able to supply you with the pin-out schematic for this inverter unit.
Posted on Jan 05, 2013
  • patvending
    patvending Jan 05, 2013
    I called the MFG and they would not give me this info. liability issues was their reason.
  • Leigh Perlmutter
    Leigh Perlmutter Jan 05, 2013
    Sorry for that. Perhaps you could find someone who has one installed that would let you look at theirs and copy the pin-out.
I need the pin configuration of Battery detection cable for MGE UPS EX7RT
Here's a link to the manual.
An RJ 45 network connector will either be a crossover or a straight patch cable. http://www.mgemexico.com/pdf/EX_RT_manual.pdf
Mar 26, 2014 | MGE Computers & Internet
Tip
TOSHIBA BIOS PASSWORD REMOVAL DONGLE
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration. But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port. Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :- 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
on Feb 18, 2010 | Computers & Internet
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
How to reset the boot password in toshiba portege a100 laptop
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Mar 08, 2010 | Toshiba Portege S100-S1133 Notebook
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Wiring diagram for sony cdx r6750 cd player
This is a link to Sony for wiring diagrams....there are 2 different plug configurations. One is the 9 pin connector.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
And the second is the 16 pin connector.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
Hope this assists you with your installation....if you need more info, let me know... Tim
Oct 23, 2009 | Sony CDX-GT300 CD Player
Installing a new power supply unit
Nothing to worry about, there are always extra connectors for different configurations.As long as you have the 24 pin and 4 pin connected to the MoBO and your CD/DVD drives and HDD are powered you'll be OK
Jul 30, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Installation of BT-146
Yes, you need to plug in a 4 pin FLoppy Molex connector. Your power supply should have at least one. The power connector is right next to the Floppy Drive connector.
Also, the Floppy connector goes in with pin 1 (The red stripe) to the left looking at the unit from the back (furthest away from power).
There is no manual to speak of.
Jan 09, 2009 | BYTECC (BT144) External Floppy Drive
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
74 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
