Question about Cell Phones
How do I fix my water damaged remote? - Cell Phones
    New Friend:
Take it apart and put it in a bowl of rice under light. the rice should absorb the water unless its been drenched. its worked for me with my water damaged phones.
Posted on Jan 05, 2013
Water damage repair
If it has been under water for 5 continuous hours, leave it off. Buy an other remote control for your device. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Feb 09, 2014 | Televison & Video
Volume control on remote does not always work. Is there something under the button that wears out? How to get inside remote to repair.
Hi, it's easy to fix. Most time when a remote volume control buttons does not work, it's usually caused by dirt inside or water spilt on the remote control, And when the button inside has moist, it responds slowly and does not respond at all.
What to do is this, Open the remote control, you will see a panel inside that controls the button functions. Use a cloth to wipe the all panel inside and close it back. Your done!!!.
But if it still those the same way,that means the damage is beyond repairs, You willneedto get another remote...
Hope it helps.
Thanks for using fixya....
Dec 04, 2010 | Onkyo Audio Players & Recorders
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
CODE C 4776 COMES ON DISPLAY AND UNIT SHUTS DOWN HOW DO I FIX THIS PROBLEM
Check the gas inlet pressure as I am guessing this is an LP unit. Most of these problems come from a poor installation. Gas pipe too small, gas pressure too low, not enough combustion air. The other cause of error codes is a unit plugged into an extension cord. Also, if the flue is not installed properly, condensation can come back and damage the unit.
Apr 04, 2010 | Rheem Tankless Hot Water Heater...
My element blue ray dvd remote is not working, can you tell me what can I do
Quick fixes-
-New batteries
-Batteries inserted incorrectly
-Not aiming at reader
More difficult to fix
-Non compatible remote
-Broken LCD sensor
-Circuit issues
-Water damage
Please contact me if you figure out the exact problem, and I will help you to fixit
Oct 11, 2009 | Element Electronics EDBCO11 Blu-Ray Player
Milk spilled on tv remote controller
Remove batteries from remote, to avoid further damage caused from liquid on powered circuits.
Allow the remote with the cover opened to dry for few days. Ideally the remote should be disassembled and the internal parts treated with cleaning solution, or 70% isopropyl alcohol and water. If you do not want to disassemble just let it there to dry up.
If the remote does not work after that , it means that the liquid had damaged circuits.
In that case get a replacement remote.
Replacement Remotes
1-800-Remotes
TV Remote Controls - UK Replacement Remote
Aug 26, 2009 | Televison & Video
Remote lock no longer works
replace remotes from dealer possible water damage in remotes
Apr 21, 2009 | 1995 Jeep Grand Cherokee
My car alarm goes off for no reason
I have the same problem with my Z3 alarm going off, a local BMW specialist has traced it to the pitch sensor which has been damaged due to a water leak, the wires are also corroded. They have quoted £200 to fix it, but advise that the water leak is sealed first because it'll just get damaged again. I've had a look round and it appears the water is getting in by the off side light cluster via the boot gutter.
Feb 27, 2009 | 1999 BMW Z3
Laptop keys not working
take off key, clean it and Bob is your uncle
Aug 28, 2007 | Zenith ZN110 Remote Control
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
