Kodak esp 3.2 will not print pdf files - Office Equipment & Supplies
  • 295 Answers
SOURCE: my kodak esp-3 printer is printing with a pink
open printer access door.remove printhead and cartridges again reseat both of them.. press copy $ cancel for 5 seconds and wait for caliberation sheet to print.. or if u have connected ur desktop, open kodak home center, go 2 maintenance and click on clean printhead. now see if ur documents are printing properly. if not kodak will replace ur printhead.
Posted on Jun 22, 2009
SOURCE: Replaced printhead and ink cartiages on a Kodak ESP.3
I had my esp3 stop printing black also. I bought new cartridges even tho' I knew the ones in the printer were at least half full. Still not printing black. I finally called Kodak support and got a tech who was the first tech from India who could speak English well. He was very helpfull but in the end he told me he would send me the printer head because that was the problem. My printer was not used for about a month and the head dried up. The tech said that printer must be used about twice a week and the best way was to print the test by using the 'Scan' and 'Copy' at the same time. There was no sense telling the tech this is a huge flaw in the printer as he must have been hearing this for a long time. After I received the new printer head it prints fine. This is an absolutely huge flaw in this printer. If they can't make a different style of head for this printer these will stop being used................. So if you have the ESP3 (I don't know about the other models) and don't use it often the head will dry up and you can't clean it (according to the tech I talked to). Kodak should send these free for the life of the machine in my opinion.
Posted on Aug 08, 2009
shockwave727
  • 262 Answers
SOURCE: how to clean print heads on kodak esp-3
Press and hold Cancel and Copy button simultaneously until the On/Off light flashes green. you will see a flashing green on your printer it means its now cleaning the printhead
You can also clean a printhead using computer., first you need to launch the Home center software On your computer and on the uppr right corner of the windows of the software click help icon(?) then go to maintenance and under maintenance you should see the clean printhead. GudlucK!
Posted on Nov 05, 2009
Testimonial: "Good advice, thanks - had already tried this tho'. I ended up phoning Kodak helpline and am having a new print head sent to me FOC."
  • 164 Answers
SOURCE: kodak esp-3 printer will not print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
  • 35 Answers
SOURCE: purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Posted on Jul 26, 2010
Testimonial: "Hi - the printer was caput - had to be replaced. Thank you for help."
I have a Kodak ESP Office 2150 Printer. Recently I purchased a Samsung Galaxy 4 Smart phone. I would like to be able to print from my phone. Is that possible and if so...how do I do it? Blessings,...
The Kodak printer has and email address that you can print to by simply emailing the file to that address.
Kodak doesn't set this up for you automatically, so you will have to do this. Do you have the manual to your printer handy?
http://resources.kodak.com/support/pdf/en/manuals/AiOPrinters/ESP_Series/ESP-Printer-Wireless-NSG.pdf
Sep 17, 2013 | Kodak ESP 2150SE Wireless Office...
Printer prints PDF but pulls page back in a few inches
Try this: Go to print a pdf file by clicking file/print. When the print properties box appears, click on the Advanced button on the bottom. Check the Print as Image box and click OK, then print your pdf file. If it still does not work, update, or delete and reinstall your print driver.
Aug 11, 2012 | Kodak ESP C315 Wireless All-in-One Printer
I tried to insert my memory card from my camera and it will not go in. Are there certain cards it will not take?
yes what kind of camera u have if u have a usb plug in the front you can buy an adapter for your camera at staples or your local electronics store..
Apr 10, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 printer will print but has lines through letterring o
Suggest you contact Kodak directly as it may need a replacement part
Jul 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Won't allow me to print
in the start search typy printers & hit entre then u will get the printer page open then try n make your current print default by right clecking in your printers icon, u will no longer have this problem
Mar 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I downloaded a manual and want to print it using both sides of the paper. How do I set up my Kodak ESP 3 to do that?
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out when you can do so.
Click LINK= http://www.4all2sell.com/pdf/Kodak-ESP-3-Manualpdf.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 05, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3:paper light flashes red,can't print-is totally useless
kodak has certain problems with esp-3 printers. it cannot give u a cash refund call kodak @ 1800 421 6699 . they will upgrade ur printer and give u a kodak esp-5. they have been giving esp-5 lately in return for esp-3
Jul 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
jasbo
jasbo
