Windshield washer does not spray the front window but sprays the roof of my car
SOURCE: mazda tribute 2003 front washers not working.
check the lines that run to the sprayers might be unhooked or a kink in the line if that does not solve check for a washer motor fuse or the washer motor its self could have burned out.
SOURCE: my wipers stopped working, i dont hear the motor
Step one, check the fuse (with a meter please). Next check if the wiper motor came unplugged (maybe during some other maintenance) Next unplug the connector, check for corrosion or damage. Check continuity to ground, or jump to battery and ground wiper motor to known good ground on chassie. Bad grounds are common on wiper motors. Or, you can use your portable 12V DC power supply if you have one. If motor works on a jump, check the switch or intermitant circuit. Good luck.
