Question about Weslo Cadence G40 Treadmill
How to check the motor on the treadmill.
Everytime i run the treadmill it trips the fuse. fuse box and fuse have been checked and they are fine. i was told it has to be the motor tripping it.
3 Suggested Answers
hasan mahmud
  • 35 Answers
SOURCE: weslo cadence treadmill fuse keeps tripping after
dear sir,
this types of problem occurred due to reason given below:-
1) if your motor belt too jammed. motor need more power to rotate it.
2) motor internal coil insulation problem.
3) semi short circuit in the internal control circuit.
how to check :-
at first look the label on motor try to find out the motor Ampere then measure with a ammeter if it drawing current is high from label mentioned ampere
then motor is faulty.
for check the circuit if u don't have any previous idea plz contact with qualified technical person.
hope that u get the answer.
thanks
Posted on Oct 22, 2009
SOURCE: my weslo cadence 4400 m6 treadmill trips out when
my tred mill runs fine till i walk on it and then trips out
Posted on Mar 23, 2010
My treadmill turns on but completely cuts out and trips the house fuse box.. whats wrong
Either your Motor or Motor Control Board(MCB) is faulty.
Try testing your Motor with a Drill Battery:
1. Disconnect the machine's power lead from the power socket, so that there is no power to the machine.
2. Open the Motor Hood.
3. Disconnect the Motor + and - leads from the Motor Control Board.
4. Connect + and - leads(normally Red and Black) to the Drill Battery.
The Motor should turn the Belt.
With the Motor leads disconnected from the MCB, you can connect the machine to the power, Press Start, and if this trips your Fuse Box you know its definitely the MCB.
Only carry out these tests if you are competent.
Lethal Voltages are present.
samsfitnesssolutions.co.uk
Jul 04, 2014 | Proform Crosswalk 500 Treadmill
I have a Ntl 1094 Track C 1900 and the problem i have is ; the drive motor for the belt trips a breaker in the house breaker box. The belt will start and run for approx 5 seconds and the the breaker...
first check and see what the circuit is rated at. it you have too many thing on that circuit(light,tv,etc) this will trip your breaker because of the amp draw of the treadmill. nordictrack recommends a dedicated circuit of 20amp. you may nned to have a circuit put in with 12/2 wire
Oct 17, 2013 | NordicTrack Exercise & Fitness
Why does treadmill keep blowing plug fuse as soon as you start to us it.
Dear Sir:
Hello, I hope everything is fine, in union with your family.
I will try to help you, inmediately.
INSTRUCTIONS: You must be carefully to do this.
    • 1
Cleanand routinely maintain the running belt. The belt may be worn if the treadmillstops operating or trips the circuit breaker or fuse. Look for any tears in the belt.Test the belt by putting the treadmill at full incline. If it does not shutoff, you may need to replace the belt. You can try lubricating it first, butthe safest fix is simply to replace it.
    • 2
Tightenthe running belt if it is loose. A belt can slip if there is too much friction.Be careful not to tighten the belt too much, though. You should be able to liftthe belt at least 3 inches.
    • 3
Pushthe belt in the direction that it normally turns. Turn off the power before youstart. If the belt is difficult to turn, there is high belt/deck friction.However, if the belt moves freely, that's not the problem.
    • 4
Examinethe roller sleeve to see if it is centered on the running belt. If not, this couldcause the belt to move to one side. Often a common problem with treadmills, youcan try making adjustments yourself, but eventually you may need to replace thesleeve or roller.
    • 5
Stopthe treadmill and immediately unplug the power cord from the outlet if younotice a burning smell. Overheating could be a sign that there is too muchfriction or a short in the wiring. Examine the belt and deck for any signs ofwearing. If they check out alright, inspect the wiring. Replace any damagedparts as needed.
    • 6
Checkto make sure that the power switch is on if you suddenly lose power. If thisisn't the cause of the power loss, unplug the treadmill from the wall outletand individually test the fuses, breakers and switches. Test the wall outletfirst, as a fuse may have blown or a circuit breaker tripped.
    • 7
Allowthe treadmill to run at a speed of 2.5 mph without anyone walking on it if younotice fluctuations in the speed. The speed should be constant. If not, therecould be a problem with the motor.
    • 8
Testthe motor using a fully charged lantern battery. The motor should still operateat slow speed.
    • 9
Replacethe batteries in the panel if it dims. If the batteries aren't the problem,check to see that all the wiring is still intact. Sometimes a wire pulls loose.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please reach me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Oct 03, 2011 | Reebok Rt1000 Treadmill Walking Belt
I started my reebok ice treadmill (REM-RE10301I) manufactured date FEB, 2009 and it began to spark and tripped my electric, i turned it back on and everything works fine apart from the belt will not move,...
First of all check the Fuse in the Motor control board. If it faulty then replace the same. If the fuse again blews the the you have to check the motor and its driver board. Using a car abttery you can check the motor. Connect the red wire from the motor to possitive terminal of the battrey and the black wire to the negative terminal. If the motor is ok the it will run without any trouble. If not then you have to replace the motor. If the motor is working perfectly then you have to check the motor control baord. It is available as modules. If you want to repair the motor control board then, You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will not run or will run at high speed. . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference
ajin_g_95.jpg ok
Sep 18, 2011 | Reebok Exercise & Fitness
Thermal overload on motor keeps tripping around speed of 3.2 when being used. Will run at 11 for 5 minutes without anyone on belt. House breake does not trip in either case
I would check out the condition of your belt and deck.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
Jun 29, 2011 | Precor 9.31 Treadmill
Will not run. i set the speed and motor still not
If you dont have voltage going to Drive Motor that means you have a bad controller.
Apr 13, 2010 | Nordic Track /proform Treadmill...
Treadmill trips electrics
Check to see that the treadmill does not draw more amp than stated in the owners manual. If you are, then the problem is in treadmill. If not try another circuit in the house (not just another receptacle).
Jan 09, 2009 | Proform 380 CS Treadmill !
Weslo Cadence G40 Treadmill Logo
37 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
