Question about Water Heaters
Sime boiler fires up every 5 seconds still works fine but very annoying
4 Suggested Answers
lynsey_el507
SOURCE: Sime Domestic Boiler
What does fault post-condenser mean? And how is it fixed? Ive got a SIME ecomfort plus HE30 and have had nothing but problems!
Posted on Oct 19, 2012
co7196
  • 3433 Answers
SOURCE: sime super 90 stopped firing up
Sometimes removing a radiator dislodges build up inside plumbing. Perhaps it would help ,and perhaps not, to see if the radiators have unrestricted flow. Radiators with shut off vavles can have a valve that doesn't fully open or close if not used often enough, Like the valve on a water line. Have your other half flush them out see if that helps. Good Luck
Posted on May 18, 2009
  • 150 Answers
SOURCE: SIME ECOMFORT 25 HE BOILER - Dripping water ???
If it's from the condenser, it's ok
Should really be piped away but a container under is also ok
Posted on Dec 22, 2009
Not getting any hot water what do i do?
I suggest getting in touch with your boiler company. They'll come out and check your thermostat, check your pipe's aren't freezing and that your boiler is igniting at least. P.s. I had this problem recently down to user error, been cold recently so had the heating on often then wondered why my water was chilly :S
Dec 05, 2015 | Water Water Heaters
I have a sime ecomfort boiler.. And no hot water.nit is showing code AL01. We have tried to reset a number of times and error code is still showing. Can anyone suggest any fixes?
The Sime documentation says for AL01 you need to "Request assistance from qualified technical personnel." Not really helpful.
Nov 01, 2014 | Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
When you turn on hot water tap the boiler fires up hot water for a few seconds the water becomes cold the boiler flame goes out then fires up again. when the heating on the flames stays on then off then on...
To avoid having a flame in the absence of water flow, the device you mentioned, 'diaphragm,' detects if adequate water is flowing to avoid a dangerous condition. Check on the housing of it for an adjustment screw; it may have a dot of sealant on it since these normally can be adjusted. It sounds as if it is misjudging the quantity of water flowing through and causing the annoying cycling.
Dec 17, 2010 | Water Heaters
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
Dec 20, 2009 | Water Heaters
Sime super 90 stopped firing up
Apr 11, 2009 | Water Heaters
Heating not working properly on my sime super 90 combi boiler
you need 15 lbs water press,bleed air from system, primary must be bad
Mar 29, 2009 | Water Heaters
could it mean circulation alert!!!
Mar 22, 2009 | Water Heaters
Water Heaters Logo
151 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
