Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Oxygen bank 1 sensor 2 - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
    Scholar:
  • 117 Answers
This would be the rear sensor on the drivers side exhaust telling you that the exhaust is not with in specs. Either a bad sensor, exhaust leak, wire connection or catalytic converter
Posted on Nov 02, 2013
Po136-o137 says change 02 sensor on bank 1 sensor2 I did but engine light is still on 2004 chevy tahoe
code p 0136 refers to heated oxygen sensor (HO2S) 2 bank 1 ---circuit malfunction===causes ---heating inoperative ---wiring---HO2S--- ECM
also refers to oxygen sensor (O2S0 2 bank 1---circuit malfunction===causes --- wiring---O2S ---ecm
it also refers to heated oxygen sensor (HO2S) 2 bank 1 ---no signal===causes ---wiring --- HO2S---
code p 0137 refers to HO2S 2 bank 1 ---low voltage -===causes --exhaust leak---wiring short to ground ---HO2S--- ECM
it also refers to O2S 2 bank 1---low voltage ===causes exhaust leak---wiring short to ground ---O2S ---ECM
to set you up here-- there are 4 oxygen sensors in the system
2 are heated oxygen sensors (HO2S) on in each exhaust manifold or exhaust pipe before the cat converter and
2 oxygen sensors (O2S) -- one in each exhaust pipe after the cat converters
heated oxygen sensors have 4 wires and O2S sensors normally only 2 wires
it is more that possible that you changed the wrong sensors and in the process damaged the delicate wires with the incorrect spanner being used
Jul 25, 2016 | 2004 Chevrolet Tahoe
Tip
Which Oxygen Sensor Is It?
There are many inquiries online about which oxygen sensor to change. Oxygen sensor failure codes are very common on a lot of vehicles. With all of today's vehicles having at least two oxygen sensors and many having three or four of them, it can be a little confusing as to which one is causing the problem.
Before we get into which sensor is which, we need to have a little discussion about oxygen sensor fault codes. There are several different types of oxygen sensor fault codes. Here are just some of the most common ones:
P0135 "Oxygen Sensor Heater Circuit Bank1 Sensor 1"
P0141 "Oxygen Sensor Heater Circuit Bank 1 Sensor 2"
P0147 "Oxygen Sensor Circuit Bank 1 Sensor 3"
P0152 "Oxygen Sensor Voltage High Bank 2 Sensor 1"
P0159 "Oxygen Sensor Slow Response Bank 2 Sensor 2"
P0171 "Oxygen Sensor Lean Sensor 1 Bank 1"
P0172 "Oxygen Sensor Lean Sensor 1 Bank 2"
P0174 "Oxygen Sensor Rich Sensor 1 Bank 1"
P0175 "Oxygen Sensor Rich Sensor 1 Bank 2"
There are many more possible oxygen sensor codes, but I only listed these to make my point. Many times the oxygen sensor code is NOT caused by the oxygen sensor itself. "Lean" or "Rich" oxygen sensor codes (i.e. P0171, P0174) are usually caused by something other than the oxygen sensor. Something is wrong, causing the engine to run lean (not enough fuel or too much air) or causing the engine to run rich (too much fuel or not enough air). In these cases, replacing the oxygen sensor will not fix a thing. (That is, unless you are trying to fix your bank account from having too high of a balance!) The new oxygen sensor will just set the same code as the original one. This is because the oxygen sensor is not CAUSING the problem, it is only REPORTING the problem.
High voltage codes (like P0152 above) can be caused by the oxygen sensor wires being shorted to another wire inside the wiring harness. Sometimes these codes are caused by bad grounds where some other component is trying to ground through the oxygen sensor circuit. Again, replacing the oxygen sensor will not fix this! In short, the problem needs to be diagnosed before running out and buying an oxygen sensor.
Just because a fault code has "Oxygen Sensor" or "O2 Sensor" or "O2S" in its description does not necessarily mean that an oxygen sensor needs to be replaced. Many do-it-yourselfers believe that all there is to fixing the car is to hook it to the "magic box", collect the fault codes and replace the parts the computer tells you to replace. There is nothing further from the truth.
Fault codes only point you toward which SYSTEM is failing. The system must be diagnosed to find the CAUSE of the failure. If this is not done properly, it will only result in wasting a bunch of your money. This is what you were trying to avoid by doing it yourself!
So, after reading all of the above, if you think you still want to replace an oxygen sensor, but don't know which one; here is how to figure it out:
Oxygen sensors are always numbered like this:
Bank 1 Sensor 1
Bank 2 Sensor 1
Bank 1 Sensor 2
Bank 2 Sensor 2
Some manufacturers use a kind of shorthand that reads different, but means the same thing:
Sensor 1/1 or O2s 1/1
Sensor 2/1 or O2s 2/1
Sensor 1/2 or O2s 1/2
Sensor 2/2 or O2s 2/2
Bank 1 is always the side of the engine where cylinder #1 is located and, of course, Bank 2 is the opposite side.
On a 4 cylinder engine, there is only one bank and it is always referred to as Bank 1. The exception to the 4 cylinder rule is on certain 4 cylinder engines (specifically, some Toyotas) there are two catalytic converters used. In this case, Bank 1 sensors will still be in the pipe for the catalyst that is connected to cylinder #1 and Bank 2 sensors will be in the other one.
Sensor 1 is always the "upstream" sensor (the one located BEFORE the catalytic converter).
Sensor 2 is always the "downstream" sensor (the one that is located AFTER the catalytic converter).
Sensor 3 refers to the ONLY "downstream" sensor where there are two sensors before the catalyst and only one after the catalyst. On very few vehicles the reference to this reads "Bank 1 Sensor 3".
If you do not know where cylinder #1 is, then you need to get a diagram of the firing order for your engine. Just post a question on FixYa.com and make sure you give the YEAR, MAKE, MODEL, and ENGINE SIZE of your vehicle and one or more of our experts will be happy to tell you how to find cylinder #1.
- DTTECH
ASE Certified Master Automobile Technician
Also check out this article by dttech: What Else Could Be Wrong?
on Apr 29, 2011 | Ford F-150 Cars & Trucks
P0141 civic code
in barstool talk:
the rear oxy is toast. get a new one.
if v6 engine, then post that, and we an tell which it is. but is bank1 no matter, bank one means side of engine that has #1 cylinder
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM) (NEVER)
Jan 11, 2014 | 2001 Honda Civic
Code p0036
Possible causes
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 harness is open or shorted
Read more: http://engine-codes.com/p0036.html#ixzz2ib20bfW1
Oct 23, 2013 | Cars & Trucks
2002 toyota avalon engine check light on P0078 and P007C
P0050 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 1)
P0054 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 2)
P0055 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 3)
P0056 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 1)
P0060 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 2)
P0061 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 3)
P0062 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector -Range/Performance
P0066 Air Assisted Injector -Circuit Malfunction or Circuit Low
P0067 Air Assisted Injector -Circuit High
P0068 (MAP) Manifold Absolute Pressure /(MAF) Mass Air Flow - Throttle Position
Correlation
P0069 (MAP) Manifold Absolute Pressure / (BARO)Barometric Pressure Correlation
P0070 Ambient/Outside Air Temperature Sensor -Circuit Malfunction
P0071 Ambient/Outside Air Temperature Sensor -Range/Performance Problem
P0072 Ambient/Outside Air Temperature Sensor -Circuit Low Input
P0073 Ambient/Outside Air Temperature Sensor -Circuit High Input
P0074 Ambient/Outside Air Temperature Sensor -Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit Malfunction (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit Malfunction (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 2)
Mar 22, 2013 | 2002 Toyota Avalon
P0037. heater sen. where is it on the engine?
The code is for the heater in the O2 sensor bank one sensor two. That would be the sensor after the catalytic converter on bank one.
It could be the sensor itself or the power supply for the heater.
Aug 25, 2012 | 2006 Mazda MPV
I have research around and found that the Bank 1 sensor 3 O2 sensor is post Cat. But when I got under there I dont see anything that could resemble a sensor. Where is it. Please help. Marc
try this
ALLDATA Editor's Note: Always verify #1 cylinder location prior to diagnosis and repair.
- Cylinder bank number one is the bank that contains number one cylinder.
See: Firing Order
printer.png View & Print Options 80_fm96hmob2_006a-159za.png&width=490&height=209&displaytype=display&imgrotation=&links=
Cylinder #1 on left side.
printer.png View & Print Options 29_fm96hmob2_006a-159z.png&width=469&height=193&displaytype=display&imgrotation=&links=
Cylinder #1 on right side.
- The first oxygen sensor in cylinder bank # 1 is numbered O2 Sensor 1/1.
- The second oxygen sensor in cylinder bank # 1 is numbered O2 Sensor 1/2.
- A third oxygen sensor in cylinder bank # 1 would be numbered O2 Sensor 1/3.
- The first oxygen sensor in cylinder bank # 2 is numbered O2 Sensor 2/1.
- The second oxygen sensor in cylinder bank # 2 is numbered O2 Sensor 1/1.
- If a V-6 or V-8 vehicle only uses one downstream Heated Oxygen Sensor (HO2S) it is numbered O2 Sensor 1/2, even if it uses two upstream HO2S.
var classElements = new Array(); var node = document; var tag = 'a'; var els = node.getElementsByTagName(tag); var elsLen = els.length; var pattern = new RegExp("(^'\\s)specs_note(\\s'$)"); for (i = 0, j = 0; i
Jun 03, 2011 | 2001 Dodge Stratus
Where is the bank 1 sensor 1 o2 sensor located in a 2006 hyundai sontata gls v6?
The bank has to do with which side of the engine. The 'Sensor 1' indicates that it is upstream of the catalytic converter.
Heated Oxygen Sensor Removal & Installation Heated Oxygen Sensor (Front) (2.4L) hyundai-04-24-5822.gif
Heated Oxygen Sensor (Bank 1/Sensor 1) (3.3L) kia-04-00-5213.gif
Heated Oxygen Sensor (Bank 1/Sensor 2) (3.3L) kia-04-00-5214.gif
Heated Oxygen Sensor (Bank 2/Sensor 1) (3.3L) kia-04-00-5215.gif
Heated Oxygen Sensor (Bank 2/Sensor 2) (3.3L) hyundai-04-33-5855.gif
Jan 13, 2011 | 2006 Hyundai Sonata
Bank 1 sensor 2 location on a 1996 chevy suburban
Fig. Fig. 3: Oxygen sensor-4.3L engines
Fig. Fig. 4: Oxygen sensor-5.0L and 5.7L engines
Fig. Fig. 5: Oxygen sensor-7.4L engines
Bank 1 sensor 1
Bank 2 sensor 1
Bank 1 sensor 2
Bank 2 sensor 2
Bank 1 is always the side of the engine where cylinder number 1 is located and, of coarse, Bank 2 is the opposite side.
On a 4 cylinder engine, there is only 1 bank and it is always referred to as Bank 1.
Sensor 1 is always the upstream sensor (the one located BEFORE the catalytic converter)
Sensor 2 is always the downstream sensor (the one that is located AFTER the catalytic converter.
Hope helps (remember to rate this).
Dec 12, 2010 | Chevrolet Suburban Cars & Trucks
My check engine light has come on in my 2006 Pontiac G6 after 2 and a half years. What could possibly be wrong since I keep my car serviced and the guys had just told me that my car was in tip top shape?
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
P0068 - Throttle Body Airflow Performance (PCM)
P0100 - MAF Sensor Circuit Insufficient Activity
Jun 25, 2009 | 2006 Pontiac G6
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
23 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
