Question about HP PSC 1510 All-In-One InkJet Printer
Hp psc 1510 windows 8 ink level check
Unable to determine ink levels since I got Windows 8.
  • HP Master
  • 5,218 Answers
You probably have a generic Windows driver installed. Assuming you have a version other than Windows 8 RT, uninstall the printer. (Go to the Charms menu (Win+C from the keyboard, IIRC) from the Desktop and choose Settings. Then choose Control Panel., Hardware, Devices and Printers. Right click on the printer and choose Remove device. Alternatively, left click on the printer and click on Remove Device at the top of the window.) Then unplug the printer data cable if you are using a USB connection.
Then go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4132&lc=en&cc=us&dlc=en&sw_lang=&product=428800#N197 to download the full software from HP. Use the drop down menu to choose your version of Windows 8 (32-bit or 64-bit). Then expand the section labeled Drivers - Full Feature software. Download and run this program. Then connect the printer's USB cable when prompted to do so.
Note: Windows RT only allows for apps to be installed from the App Store. I do not believe that HP has an app for the printer.
I hope this helps.
Posted on Jan 05, 2013
5 Suggested Answers
SOURCE: Ink levels
Open the printer preferences, click on the services button, locate "Ink Levels" and voila!
Posted on Mar 08, 2008
BobbyR1234
  • 173 Answers
SOURCE: ink lvels
Hello holliston,
You can try the following steps that should help you determine your ink levels.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Posted on Sep 06, 2008
SOURCE: hp psc 1410v ink levels
i want a solution to my hp printer for window vista
Posted on Dec 12, 2008
  • 54 Answers
SOURCE: how do i get the ink levels on my HP PSC 1510 All-in One printer?
Go to start, parameters, printers chosse the printer click right mouse button properties....usally you will everything there
Posted on Feb 28, 2009
I want to check ink levels. It is blurring the color when printing
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Jun 21, 2011 | HP LaserJet CP1518 Printer
HOW DO I CHECK THE INK CARTRIDGE LEVELS HP PSC 1500
You can check it on the settings>Ink levels on the printer software
May 14, 2011 | HP PSC 1510 All-In-One InkJet Printer
How i check the cartage level, i am unable to doo that, plz help me...if have to any command direct to see ..please let u inform me..My printer is HP Clour Laser Jet 1600 ...
Check ink levels Use one of the following methods to check the ink levels. NOTE: If you have installed a refilled or remanufactured print cartridge or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable. Method one: Use HP Solution Center to check ink levels HP Solution Center is software that acts as a centralized point of access for tasks such as scanning, printing, and copying. The software is part of the software package that comes with your product. When you perform a standard installation of the HP software, HP Solution Center is automatically installed. You must have the full-feature print driver, which includes HP Solution Center, installed to use this method. If you do not have the full-feature print driver installed on your computer, you can install it now. Alternatively, you can use 'Method two: Check ink levels from the software program' to check the ink levels. Click this link (c02463264) (in English) to see instructions for installing the full-feature print driver and HP Solution Center.
  1. Open HP Solution Center.
    • Windows XP : On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista : On the Windows taskbar, click the Windows icon (c01364735.gif), click All Programs , click HP , and then click HP Solution Center .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Programs , click HP, and then click HP Solution Center .
  2. Click Settings , and then click Printer Toolbox .
  3. Click the Device Services tab, and then click the Estimated Ink Levels tab.
    or try this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&tmp_task=useCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=390328&key=null
Apr 05, 2011 | HP PSC 1600 InkJet Printer
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
Oct 05, 2010 | Office Equipment & Supplies
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
How do i get the ink levels on my HP PSC 1510 All-in One printer?
Feb 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
Ink lvels
Hello holliston,
Sep 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Hp psc 1410v ink levels
Jul 01, 2008 | HP PSC 1410v All-in-One Printer
Ink levels
Mar 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
