Question about Ricoh Aficio CL3500N Laser Printer
Sc 441 error massege - Ricoh Aficio CL3500N Laser Printer
    Master:
  • 339 Answers
The SC441 error means one or more of the developer units (PCU) is not rotating. You have to take the PCU out to see which color isn't rotating. One of the doctor (cleaning) blades might be flipped, usually caused by lack of toner in the PCU.
Basically, if you just open up the printer, latches and everything, and just make sure the parts are all able to move freely by giving them a bit of a test with your hand, then close the printer up turn it off then back on and it should be working.
Posted on Jan 05, 2013
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
jaylex
  • 417 Answers
SOURCE: SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Posted on Jan 13, 2008
SOURCE: SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Posted on Apr 14, 2009
SOURCE: sc 441 error code
Yep Master... That is what the RICOH service manual says. They do not want you to know about their design flaw, or maybe they want to sell more PCU. In any case follow Lariatsd idea. it does work. I tried it already. The manual is only as good as those who write it. GM blew up a lot of deisel (gasoline blocks in the early 80's) engines replacing the injector pumps. but that came down to a small part that regulated back pressure in the fuel system that was a design flaw. Made one that was self cleaning then all was good, but too late for those engines But the manual said replace the injector pump! So they did..... Try it, you are going to toss the PCU anyway.
Posted on Sep 19, 2009
elix0411
  • 3530 Answers
SOURCE: Error Message for Ricoh CL 3500:
Welcome to Fixya
SC441 error means that one or more of the developer unit(PCU) is malfuntioning or not rotating. Take out the PCU out to see which color is not rotating. There maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Thank you for using Fixya!
Posted on Dec 01, 2010
Error 441 mp 4000
SC 441 Trans/development motor error - check for binding/overload on motor -Carl
Feb 25, 2015 | Ricoh Office Equipment & Supplies
Error sc 441 mp4000
Feb 25, 2015 | Office Equipment & Supplies
Code of error SC 441 (Ricoh Aficio mp 6500 ...my i know what is the problem's about?
SC441: Development motor lock
-Definition- [D]
The development motor lock signal remains low for 2 seconds while the
development motor is on.
- Possible causes -
• Too much load on the drive mechanism
• Development motor defective
Feb 04, 2014 | Office Equipment & Supplies
Error sc 441
SC 440 main motor malfunction.Check the gears and the drum motor mechanical parts on the drive transmissions.For more details please the copier model.
Mar 05, 2013 | Ricoh Office Equipment & Supplies
Repair error 441 in cl3500dn printer
SC 441 - development motor lock.Possible causes:
too much load on the drive mechanism
development motor defective
poor drum motor connector connection
interface board defective
Feb 03, 2013 | Ricoh Aficio CL3500N Laser Printer
Mar 03, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
SC 441
PCU is not locked.
• Defective gear
motor clock
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
173 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
