Question about Little Giant Plumbing
Little Giant pump model 977459 (581507) sounds like the motor is frozen, you can hear the motor trying, but no blades spinning.
Little Giant pump model 977459 (581507). Can it be fixed/rebuilt? How do you oil the pump (as it suggests, the pump and tank were given to me me so did not know about the oiling)
reg501
  • 413 Answers
SOURCE: Burning Smell when spinning
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Posted on Jun 10, 2008
SOURCE: Blade not turning
I am looking at the same problem, the aluminum bottom part (on blade assembly) that contacts the black rubber on the motor part is no longer "attached" to shaft that drives the blade on top side. So like said the top and bottom "turn freely" but independent of each other.... not good, they should be one piece. Ebay does not have a replacement for this original part in my case and would have to buy a complete jar assembly. I will attempt to fix the original one by cutting a slot through aluminum and center shaft and dropping in a pin to make them turn together, with a spot of weld to hold pin to shaft... not sure how long this will last.... unless somene has a better idea to fix it?
Posted on Oct 29, 2008
bunnydawg
  • 5158 Answers
SOURCE: Oil pressure light comes on then goes off in 2003 VW Passat.
it's expensive but not as expensive as replacing the engine... was the oil pressure checked ?
Robert
Posted on Jan 28, 2009
  • 10 Answers
SOURCE: Low oil pressure light comes on and goes off
the noise is the chain tensioner in the cylinder head between the two camshafts. it is a job for a proffesional shop. the 1.8t passats had an oiling problem and were fixed with a larger oil filter. some times you have to remove the oilpan and replace the oil pickup tube.
Posted on Feb 15, 2009
  • 76 Answers
SOURCE: husqvarna 235 oil not getting to chain
try using thinner oil
Posted on Jul 16, 2009
I have an external little giant water pump 3qxmd nothing wrong with pump motor hums not turning can ot be fixed it it 110v
Unplug and try freeing up the impeller by hand. You may have to remove bottom of pump to gain access.
Feb 15, 2017 | Little Giant Plumbing
Who makes the motors for little giant pumps 3-MDQX-SC
Try taking it to a Grainger's store or go online to Graingers.com. There are usually enough numbers on the motor to find a match if there is one available.
Oct 21, 2014 | Little Giant 581507 3-MDQX-SC Magnetic...
Little Giant 506065 - 2 did not work after 21 days, different pump better?
Are you running these pumps full-time, even if they're dry? If you are, that's far beyond their design. The sink should drain into a sump or cistern, then the pump should empty the cistern on demand from a float switch.
I don't know of any pump except possibly a bellows-type bilge pump, that can be expected to run full-time, even when dry.
Aug 13, 2014 | Little Giant Plumbing
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Only way to shut off Little Giant sump pump is to unplug it. What is making it run all the time?
Assuming that your pump has a built in float switch, I would suggest that the float switch is frozen, stuck or damaged. If you have an underwater pump that does not have such a switch then it probably is designed to only be used manually. I have a little giant pump which is designed to go underwater but must be plugged in to use and unplugged to stop. I'm assuming you have had this pump a while and in the past has always worked automatically. Again , if yours is automatic, it's the switch. Unless it's a simple thing like a frozen arm, I doubt you can fix it unless you can replace the entire waterproof assembly without tearing into it. It must remain waterproof to be electrically safe.
You may find that only a factory repair will be the proper solution.
Nimsgame
Feb 15, 2011 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Jul 07, 2010 | Little Giant Submersible Fountain Pump
My little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
Pump stopped
Possibly just blocked up, try taking it apart, and see if anything is stuck in the "Impeller". If it isn't that then it may be the Motor, or the Connections to it.
Feb 10, 2010 | Little Giant 3 Mdqx Sc 1100 Gph, 1/15 Hp...
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Plumbing Logo
100 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
