FixYa.com
Tags:
NEC-Mitsubishi Nec Display Solutions DiamondPoint V71LCD  17 in. Flat Panel LCD Monitor
DiamondPoint V71LCD Not displaying image
posted by Godzkid4sure on Jun 27, 2007
When the Monitor is 1st powered on or turned on the image comes up for about 2-3 seconds then goes blank. after a few seconds more I see it darken very slightly, as if the back light is turning off. At this point pressing any of the front buttons other than power will not do anything. If I disconnect the video in cable a display comes up, also fro about 3 seconds, says Video Input No Signal. pushing any of the front buttons at this point brings up the same box for about 3 seconds. I looked to see if the image was on, but without the backlight, but I don't see any image. Do you have any suggestions?
Comment by Godzkid4sure, posted on Jun 27, 2007
You are right there is a faint image, but why is the light coming on when turned on? Even if I turn it off then imediately turn it back on the light comes on for about 2 seconds.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
CompuGuy44
Rank:Wiz Wiz
Rating: 83%, 708 votes
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Rating Locked! (?) Godzkid4sure has rated this solution as Helpful
Can you Help with these Monitors problems?
Monitors
22" flatron (W2252TQ)...
I have two problems. I was... Answer This...
Monitors
broken pins in monitor cable
I broke off a pin by accident... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
