Question about Toshiba Satellite U305-S2804 Laptop
Power wont turn on..battery led flash orange
When plug-in ac adaptor ac led light blue and battery led light orange after few mintues battery led start flashing orange..but no power no movement sometimes laptop turn on but shut off automatically..i also treid without battery pack but nothing happen..plz help also give me solution what i do with this laptop? i am begainner laptop technician if u have any technical solution or trick suggest me i will do myself....thanx
  • Toshiba Master
  • 7,627 Answers
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Posted on Jan 05, 2013
  • 1019 Answers
SOURCE: wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Posted on Dec 18, 2008
askmenow
  • 22 Answers
SOURCE: lap top wont work
Hi
You may need a new battery. I would download software to check the battery.
Does the computer start with the AC plugged in and the battery removed?
What type of Laptop Do You Have?
/Shawn
Posted on May 19, 2008
  • 81 Answers
SOURCE: blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Posted on Nov 30, 2008
SOURCE: Toshiba Satellite A55 Series S1063
The blinking power cord icon indicates that the battery is not charging, or is defective enough that it is overloading the charger. The laptop will not turn on unless it "thinks" the battery is charged enough to operate the computer. Even though you have the AC power connected and your adapter may be OK, it is still possible that:
  1. The power jack in the rear of the computer may be broken or otherwise defective, as well as the electrical connections to it.
  2. The wires and/or circuitry which connects from the power jack to the battery contacts may be defective.
  3. The battery itself may be defective.
  4. Can you operate the computer with only the battery?
  5. DON'T try to operate the computer with the battery removed, as this can lead to a situation where the internal power supplies receive too high an input voltage. This varies from model to model, but it is generally something to avoid, since there is not much detailed information available showing the circuits in detail, we cannot make a good "guess" as to whether this may be a problem. Best to be on the safe side.
  6. If you have checked the above items and have not learned anything new, AND, you have removed the battery and adapter, turned the computer off (not in that order, of course!), and let it sit overnight, and it still exhibits the same problem, that means you have "something wrong" inside the case which will require "major surgery". That is best done by a technician familiar with Toshiba laptops, and preferably, familiar with this particular model. He should also have access to proprietary Toshiba repair documentation and test procedures. I've learned from experience that it usually does more harm than good to "poke around" inside any computer if you don't know precisely what to look for, what to do, and how to repair problems you find. Unlike simpler electrical or mechanical devices of the past, you can't learn very much be observation and tinkering inside a computer! Too much is hidden from view, or depends on special parts which can't be fixed even if you determine they are defective; they must be replaced.
  7. This is about all you can do from outside the case. If you notice any other symptoms, no matter how isolated or trivial they may seem, please let me know and I will see if there is anything else I can recommend. Unlike desktops, laptops are not made to be easily repaired by replacing circuit boards, add-in accessories, etc. They are pretty much self-contained. Once you determine that the problem is inside the case, first you decide if the laptop is still worth enough to warrant the hundred-dollar-plus cost the repair is likely to require, or if it would be better to replace it with a new model, or look for a used one on eBay or some other place. This is not a conspiracy by Toshiba; it is just what is necessary to get everything into the small package and keep the price within reason.
Larry
Posted on Jun 05, 2009
customers184
  • 154 Answers
SOURCE: toshiba a215-s5837 problem, ac light only flashes
You may have a bad battery. Many times laptops will not work if the battery is faulty. The first step would be to replace the battery with a new one.
Second Step: If the battery is working, then you may have a faulty AC power supply. It may be enough power being brought to power up the LCD light, but not the computer.
Third Step: Yoru mother board circuitry could be bad in the sense that some circuits are broken or the power conduit is not supplying the power to the rest of the circuits on the board.
If you are not a professional and able to troubleshoot in this manner after testing the batter and AC power supply, then I would suggest taking the laptop to a store for them to test the circuitry flow of the mother board.
Posted on Dec 30, 2009
Testimonial: "my plan exactly"
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Apr 07, 2015 | Dell Computers & Internet
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
Wont turn on
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Toshiba Satellite U305-S2804 Laptop Logo
660 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
