I already tried all the options to start my computer, but the same thing happens again nomatter what i do. this blue screen just flashes really fast. then it goes back to the boot menue.
    New Friend:
I'm so sorry but the only way is to reset it, which I cannot explain as I no longer have a laptop i apologies
Posted on Jan 05, 2013
    New Friend:
  • 4 Answers
That blue screen is called BOD (Blue Screen Of Death).so I am sorry to say that you will have to do a clean install of your operating system.
If you need some of the data off it take it to a computer repair shop they may be able to retrieve some of it.(but do this b4 you do a clean install). Hope this helps
Posted on Jan 04, 2013
nipperthedog
  • 13 Answers
SOURCE: LAPTOP WONT BOOT/START
To go through the recovery program I think you tap the F11 button as you start up. Press the power button and keep tapping F11 until the recovery program starts. I have restored my easynote L4 back to factory settings twice with this utility.
However, I get the impression you have already done this and you are experiencing what's known as the Blue Screen Of Death BSOD. Don't let this term frighten you, it doesn't mean the laptop is fried. My laptop only came with 250mb of ram, so I upgraded and installed another stick in the spare port. Had you installed any more ram yourself? As postmanfw says...need to know what was happening before you tried to restore back to factory settings.
Posted on Jan 06, 2008
lolita
  • 385 Answers
SOURCE: Toshiba Satellite P105-S6084 Laptop Boot Problems.
This happens sometimes due to faulty memory or faulty software that causes errors in filesystem. You need to obtain a Windows XP with the correct edition that is installed and boot into it. Then go into Recovery Console and wait for the c: prompt asking which windows you want to log into. Select 1 for C: windows. Then it will ask you for the administrator password. Enter it or press enter if there is no password. Type chkdsk c: /r at the c:\windows prompt and leave to run. It will take about 15 -30 mins. When finished, type exit and press enter. Press ctrl+alt+del to restart computer.
If problem is fixed, computer should start up fine now.
If you still have the problem, let me know so we can try something else.
Thanks,
Lolita
Posted on Jun 18, 2008
SOURCE: I have an acer aspire one and it will not load
Was your BIOS changed recently? You may need to get in there and choose "Load Optimal Settings". Your processor may be overdoing it.
If that wasn't it, take your Windows disc and put it in the drive. Press "r" to run a system recovery.
Then press "c" for the recovery console.
then run a "chkdsk" after appropriate password has been entered.
This may fix your issue. If not post a comment and I'll help you some more.
Posted on Jul 14, 2009
  • 942 Answers
SOURCE: when trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
Posted on Sep 25, 2009
parrotheadpc
  • 2600 Answers
SOURCE: ibm thinkpad r50 notebook won't boot
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 15, 2009
I have a Dell Inspiron 2650 laptop with operating system windows xp profesional. That happened after I downloaded a software called orbit downloadable. I went into my computer and clicked start,...
try to run windows f12 boot format it should be runing on f2 this way you can go straight to problem then asked to run windows again after you restart .
Feb 04, 2011 | Dell Inspiron 2650 Notebook
I am turning on my aspire and it will ask if I want to repair or start windows normally. Which is odd because with my last usage I just shut it down. And so I just say start windows normally. The starting...
hello, i think you will need to reinstall your operating system, its has crashed. you cannot predict electronics gadget they fumble when lest you dont expect it to happen. after reinstalling and same thing still happen that means your hard disk it at fault.
Dec 23, 2010 | Acer Aspire AS7745G6572 173Inch Notebook...
My compaq presario keeps restarting itself from when i turn it on. it never makes it past the windows xp logo. a blue screen flashes really fast and then the computer restarts itself. Then the same thing...
hi this sounds like you might have a corrupt boot system file, normally the way i have solved this is to re-install windows as a repair ( not a full install ) what i mean is start system up with windows disc in, when prompted go for install, when it gets to a page that says something like, do you want to run repair or clean install run repair, it will seem like it is installing but all its doing is repairing the corrupt file system, when it is finished your system will be as you had it before, apart from my documents, that cleans that out...hope this helps
May 10, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
My Compaq was working fine and now when I turn it on it seems to be doing the right thing then just flashes a blue screen and restarts. Never actually opens windows xp for me to do anything on the laptop....
what is the blue screen you are getting as you have mentioned all the troubleshooting options the only option you can do now is either do a system restore or do a operating system reinstallation
Jan 04, 2010 | HP Compaq Presario V2000 Notebook
My turn signals started blinking really fast, and
Yes it is an easy fix. more than likely it is your flasher.
Nov 18, 2009 | 1987 Ford Mustang
I have a eee pc 900hd and I keep getting the safe mode option
if a blue screen pops up with white writing theres something seriously wrong with your laptop a blue screen on a computer is the worst possible thing that could happen apart from the thing actually exploding and can be caused by a wide range of things, my suggestion would be to reinstall windows as it will basically give you brand new computer with no errors
Oct 30, 2009 | ASUS Eee PC 900HD Netbook
Computer (thinkpad T40) shut off abruptly, and now won't re-start
your windows files are corrupted try reinstalling your windows or try a windows repair
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
Toshiba laptop when desktop is loading screen flashes and starts over again every 10 seconds
If this happens consistently, there is probably a Blue Screen occurring that is too fast for your eye to see.
Immediately after the Toshiba splash goes away, start pressing F8 until the startup options menu shows. Choose Disable automatic restart on system failure. This should allow you to see the error. then re-post with all details including the error code numbers. Then you can get help for the underlying problem.
Dec 30, 2008 | Computers & Internet
Laptop boots then shuts and continously does it
you really need a recovery CD, or windows operating system.
try removing any external devices ( Printers/scanners/ USB devices et,c ) And start the computer up with bare minimum devices attached/connected. it may be one of the external devices causing your problem.
Mike @ Compurepair.
Jun 08, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
