Question about Thetford Norcold DE0051 Refrigerator
Norcold 841 R I need door seals without buying whole door inset where can I get them
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 101 Answers
Http://thetford.com/HOME/PARTS/NorcoldIncRefrigerators/tabid/334/Default.aspx look for your part id then search for it by part # on google.
Posted on May 17, 2013
Thetford gas igniter burns but ignition is not seen by control unit
Without the make & model...
the only answer possible is a "TYPICAL" SWAG: Looks like NORCOLD is most likely your manufacturer (although I've also seen U-Line).
SPARES are good to have... (now you understand).
On-Line parts abound everywhere... It is likely an "electric"
(because of your control board statement).
I'll put up sample Pix from Amazon & eBay.
http://www.ebay.com/sch/i.html?_nkw=Norcold+Refrigerator+Thermocouple
Your THERMO-COUPLE (flame monitor)... same (type) thing that always fails on our water heaters... typically costs $6 if you are buying one in advance... up to $24 (twice that for the "Refrigerator versions" $12 to $48) in you hour of need... Unless you call a "service" (plumber) person... Then just start adding on those ZEROs.
These also can use an INTERRUPTER (same price range)...
Buy them both... As you can tell... they are good spares to keep around (I always buy a NEW thermo-couple & put it on a nail
with a "NEW water heater installation (keeps evil spirits away).
I'd recommend you post the complete make, model & year...
Defective GAS appliances can be quite deadly... even if the work is done properly... improperly the sky (is quite literally) the limit...!!
Could NOT more strongly URGE... Buy and USE a good carbon-monoxide monitor/alarm.
Truly a LIFE-SAVER.
All gas utility companies will (or used) to QUICKLY send out their representatives to inspect/light gas appliances..
Historically this was always a FREE SERVICE...
(but sadly that the extent of my knowledge... HISTORIC).
Be safe... Comment me back if you need:
(never test for leaks with a match... My grand-daddy taught me that (course hair & eyebrows grow back... MOST of the time).
Norcold Refrigerator Thermocouple
Apr 11, 2016 | Refrigerators
Norcold DE 828 on my boat. Haven't been able to replace door seals as no one makes them anymore. Compressor was always loud and always coming on. Recently, no compressor noise only a buzzing or...
Hi Macias
Norcold still should have door seal parts available for this, the parts manual available at this link
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/DE828EV828Series/tabid/499/Default.aspx
If the compressor is working then the condenser at the back should feel warm while the compressor is running, some of these have a single compressor and some two compressors, the units are fitted with independant power supplies so I would check these first. If you need any further info please come back to me
Regards
Gordon
May 05, 2011 | Refrigerators
Leak in rear lifthatch water leaking into rear storage area. It appears to be getting in under the rubber gasket door seal
Hi this is quite a common problem, you have a couple of options you can either go out and buy a new door rubber seal or if it one of those seals where you can get you hand in between two parts of the seal then what you can do is get some thick string and run this in the middle of the seal doing this will pack the seal out a bit and then when the door is shut this will make a lot better seal and it will then stop the water getting in.
let me know if you need further assistance ok
ps the rubber seal isnt to expensive to buy but even a new rubber may still have the same problem as its more to do with the way the door is fitted and it seems it dont push the seal hard enough to prevent water getting in so i have found packing it out with some thick string or twine will push the seal out more and will seal it properly when you shut the door to
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | 2007 Chevrolet Equinox LS New Cars
Dishwaher was inoperable for 2 weeks waitng for part, now theres a horrible smell like old water that perhapl leaked into the wall-the repair man did not take the whole unit out--i've put bleach,...
You should take out the filters in the base of the sump and clean them. also clean the sump. Then take off the door outer liner and clean along the bottom of the door seal. The bottom of the door seal is the worst place whaer a build up of greas forms. Once the lower door area is clean and the sump is clean get som descaler and run it through without dishes. You can buy dishwasher descaler or dishwasher cleaner from the supermarket. Keep the lower door seal clean regularly. dont put dishes i the machine with food on them. Dishwashers are not able to dispose of garbage, just grease from dishes. Good luckPS vinegar may help too.....
Aug 01, 2010 | Dishwashers
How do I replace the frame for the door? Is it
Actually it is more realistic buying the door and glass complete. Price difference is not excessive. Removing plastic d/layer "glass" dissrupts the seal and small nitty gritty items break. Must be 100%good seal for microwave action.
Sep 24, 2009 | GE JVM1650 1000 Watts Microwave Oven
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Nikon D80 battery door
Here is the contact information for Nikon parts in the USA:
841 Apollo Street, Suite 100, El Segundo CA 90245
(310) 414-8107, (310) 322-6979
Feb 29, 2008 | Nikon D80 Body Only Digital Camera
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Thetford Norcold DE0051 Refrigerator Logo
154 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
