Question about Wahl 8841- Beret Beard Trimmer
How do i Reassemble wahl beret trimmer blades, including spring?
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
rick_stokes_
  • 61 Answers
SOURCE: I have Wahl vision 180 B & M trimmer M 9858,
It is very likely that one of the plastic pieces that hold the spring mechanism broke. If you send it back (with all the pieces and clipper) to Wahl Clipper, 2900 N. Locust St., Sterling, IL 61081, they will probably fix it for you for free.
Posted on Sep 30, 2009
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Posted on Dec 04, 2009
SOURCE: How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Posted on Oct 09, 2011
Wahl groomsman model 9855 maintenance
sorry but would have to see it in person .
Dec 19, 2015 | Wahl Health & Beauty
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
How do i put back the blades on a wahl 9918C beard trimmer
You connect the blades together with the plastic part the correct way through the top of the small moving blade. The plastic part becomes a guide to keep the 2 blades running straight and true. Then engage the plastic part into the motor cam shaft and the 2 tension springs at the same time and wriggle it onto the screw hole posts and fit & tighten the screws. Lubricate and you're done.
Jun 22, 2014 | Wahl 9918-600 Beard Trimmer
It makes loud noise when i turn it on
you can not fix the noise if you are using the outliners outside of the usa.....just open the clipper up and fill it with sponge. Mainly around the top of the clipper....it has to be enough to stop the motor from vibrating so much without putting so much pressure on them the blades cant move quickly. after you have done that you may find that the noise will stop depending on how tightly you have screwed the casing back together.....it may take a couple of days of using the clipper and allowing it to heat up a bit for the sponge to mould around the motor. but at the same time using this method will amost definitely effect the performance of the trimmer. if i were you i would bite the bullet and ditch them and perhaps look at a trimmer thats manufactured for countries outside of the u.s.a.......i know the wahl lithium beret is a very sharp blade but doesnt have the t blade....i would still recommend the beret over a t shaped blade like the wahl detailer because it is sharper
Jun 28, 2012 | Andis T-Outliner Hair Trimmer
I'm overseas in Korea and everything is 220 instead of 110. When I put the 110 converter on my trimmers it makes a very loud noise.
you can not fix the noise if you are using the outliners outside of the usa because even though you are using a transformer to adjust the voltage it doesnt change the hertz and that is what makes it make that noise.....just open the clipper up and fill it with sponge. Mainly around the top of the clipper....it has to be enough to stop the motor from vibrating so much without putting so much pressure on them the blades cant move quickly. after you have done that you may find that the noise will stop depending on how tightly you have screwed the casing back together.....it may take a couple of days of using the clipper and allowing it to heat up a bit for the sponge to mould around the motor. but at the same time using this method will amost definitely effect the performance of the trimmer. if i were you i would bite the bullet and ditch them and perhaps look at a trimmer thats manufactured for countries outside of the u.s.a.......i know the wahl lithium beret is a very sharp blade but doesnt have the t blade....i would still recommend the beret over a t shaped blade like the wahl detailer because it is sharper
Jan 07, 2011 | Andis 04603 Hair Trimmer
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
Does the Wahl Model AC Trimmer have an adjustment for the blades? There is only a plastic insert between the blades
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Feb 22, 2010 | Wahl AC Trimmer Hair Trimmer
I have Wahl vision 180 B & M trimmer M 9858, with 3 complete parts separated:a)a 1.5" x 1.5" flattish blk plastic & metal piece with cutting 'comb' at the end; b)a 1" x 1.25" Blk & metal piece...
Sep 17, 2009 | Wahl Vision 180 Beard Trimmer
Wahl 8841- Beret Beard Trimmer Logo
181 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
