Question about Frigidaire PLMV168 Microwave Oven
Frigidaire GLMV168KQ2 display very dim
LCD display very dim.
Adjust display brightness on frigidaire PLMV168
Good Afternoon Friend,
I understand that the display on your Frigidaire microwave, model# PLMV168, is dim and you are wondering if there is a way to make it brighter. There is not a way to make the display on your microwave brighter. That is the particular design of your appliance. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire PLMV168 Microwave Oven
Microwave display dim
It's replaceable... but not worth it...
Apr 09, 2014 | Microwave Ovens
Display very dim
Thats just judgemental, depeding on sentimnets you have for it...ask yourself a question: why would you buy a new MW if the one you have does the same as the new one you would probably buy?
Nov 28, 2013 | Frigidaire FMV145K Microwave Oven
Frigidaire FPBM189KF microwave digital display is barely visible
Hi Gary, thank you for your post! Often if the display LED's are dimmed, it is because the issue may be related to a communication error with Main Control board or a potential wiring failure. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Aug 01, 2013 | Frigidaire FPBM189KF
Fgmv174kfb dim display
The owner's manual (here) does not mention that as a feature, so I would assume the oven has a defect and would need to be returned to your dealer to be exchanged under warranty.
Oct 25, 2012 | Microwave Ovens
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Nov 10, 2008 | Frigidaire Microwave Ovens
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Microwave display - digits have become dim / partialy missing
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 09, 2007 | Microwave Ovens
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Digital display lighting
The solution depends first on the type of display your microwave has. Please refer to the picture. The left side shows a partially defective LCD type display. If you have this type of display, we regularly repair them for $32.50 nationwide. The right side is a VFD type display which is weak due to age. On some brands and models, we are able to get a replacement display tube and repair it to a like-new brightness. Feel free to e-mail me at _ if you have other questions.
Sep 17, 2006 | Frigidaire FMT144G1 Microwave Oven
Frigidaire PLMV168 Microwave Oven Logo
55 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
