Teac A-5300 reel to reel service manual
Reel to reel only records in one channel. Playback in right and left channel is fine. Any ideas? I need a Teac A-5300 reel to reel service manual. Anyone have one or know where I can get one free.
  • Audio Player... Master
  • 1,258 Answers
Try Hi Fi Engine first and then owner-manuals.com and the best solution is from stereomanuals.com which is where I get my manuals.
http://www.stereomanuals.com/index.htm
Posted on Jan 06, 2013
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
SOURCE: i need a service/owners manual fora tascam 38 reel
they are available on ebay, but not free.
Posted on Mar 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a TEAC 3340 reel to reel recorder and
No, that would require slowing the capstan or making its diameter smaller for the rpms it turns now. Sorry.
Posted on Mar 18, 2010
Testimonial: "Speedy response with the exact information I was looking for. Thanks for the help"
  • 9 Answers
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
Posted on Jun 08, 2010
Looking for a Teac X10 reel to reel recorder User manual Not service manual Can anyone help please?
It should be found as a Pdf file on Hi FI Engine or for $5.00 at owners-manuals. com as these places usually have the common manuals.
Mar 19, 2015 | Teac Audio Players & Recorders
Reel recorder
The A4070G can record in each direction but has a switch that needs to change to switch the heads. This must be stuck after all this time and so the deck needs service. They are not easy unit to work on. I have one in my shop now. The bad news is that they use combo record and erase Ferrite heads that can not be sourced anymore.
I am very familiar with this model as I worked at Teac and fixed many of them.
Apr 20, 2014 | Teac Audio Players & Recorders
Right Side Playback Very Low
First check your connections. Then playback a known good recording. That way you'll figure out if is the machine has issues with the playback or not. If that is no good then too then clean the playback heads and check it. Then try swapping out your cables or using different jacks on your amp. If the payback is good then clean the record head with a Q-tip and alcohol. Then try a new recording and check it. If it still is no good then invest in a demagnetizer, but use it sparingly. Also it could be that the record level knob is not making a good connection. Put some headphones on (connected directly to it) to hear the recording and try moving it back and forth. If you hear some static, it may have oxidation building up. Deoxidation spray does wonders.And if none of that does the trick, you will likly have to take it in and get the preamps replaced. Good luck.
Jun 18, 2012 | Audio Players & Recorders
How do I connect a teac ax-20 mixdown panel to a teac a-3340s reel to reel?
It's a 4-in, 2-out panel. Well, you attach up to 4 INPUT channels (labeled plainly on it) and run the two output channels to any two of the the Record In connectors on the Tape Deck.
Sep 11, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
Hello there, I've purchased on eBay my Sony TC-200 Reel to Reel recorder. I've opened and cleaned it to best of my knoweldge and ability. I am able to hear sounds on both speakers when I connect my...
http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/TC200 Go here. when the page opens, click on the TC200 to download the service manual. There are 3 tubes and one transistor in each channel. Test the tubes first. They fail with age. You can still get tubes. You just have to google the tube number to find a seller.
May 15, 2017 | Quantegy 456 Reel-To-Reel Recording Tape
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
May 11, 2010 | Audio Players & Recorders
Capstan motors of Teac X7 rotate only manually (very stiff)
Allied electronics still has these small motors. They probably won't have the same part numbers though. You will need the printed information from the motor as well as accurate dimensions for an accurate comparison.
Good Luck.
Dec 15, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Oct 13, 2007 | Arris DCT6200 DTV Receiver
310 people viewed this question
 Grubhead
Grubhead
