Question about Home Security
How to disconnect life saver smoke alarms model 1275
We want to replace them with a newer model. how do we unwire the old ones ?
    New Friend:
There is a video that shows the disconnection and head removal
http://www.safelincs.co.uk/video_player.php?vid=42
Posted on Jan 05, 2013
  • harry977
    harry977 Jan 05, 2013
    there is a video that shows the disconnection and head removalhttp://www.safelincs.co.uk/video_player....
3 Suggested Answers
TeaCii
  • 90 Answers
SOURCE: Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
  • 8457 Answers
SOURCE: does kiddie 1275 smoke alarms
No,this thing a smoke alarm detectors,damp air doesn't set it off.
Posted on Aug 29, 2011
Any body out there?Is my question to tough for you.There is no battery in a 1275 Kidde smoke sensorIt started beeoping,still does.What is the answer please?
Download manual
If the unit is chirping once per minute it is probably indicatiing low battery, although other malfunctions can sometimes cause the same thing. According to the manual (see the link), the 1275 DOES have a 9V backup battery, but be advised that if the unit is more than 10 years old the entire smoke alarm must be replace per the national fire code (NFPA72). Many of today's smokes come with a ten year non-replaceable battery for that reason. Hope this answer helps.
Sep 26, 2015 | Home
How to stop chriping problems
Usually it's just a matter of replacing the battery. Replace the unit if it's more than 10 years old (mandatory per NFPA 72) or if replacing the battery does not work.
Sep 07, 2014 | Kidde 1275 Hardwire Smoke Alarm with Hush...
How can I make my kidde 1275 stop chirping. We've changed the batteies
if the batterys are good then there is a fault in the supply from them to the board
Dec 24, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde Smoke detector 1275 continues to chirp. I located the detector and opened it but I can't get to the battery. Please help
When you say you opened it, what do you mean? The unit should come off the trim ring and expose the bottom which I believe is where the battery is located. Just so you know, if the unit is more than 10 years old the entire unit must be replaced per NFPA 72.
Sep 19, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
How do I stop the three pulse alarm pattern, I have checked my house and their is no danger.
You should check all the units when this occurs (this is an actual alarm sound) to see if one of them is different than the rest, either by flashing an led, turning on a red led, etc. The one that is different is the one with the problem; replace it. If your units are more than 10 years old you need to replace all of them by code (NFPA 72), just so you know. Good luck!
Sep 17, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde smoke alarm won't stop chirping . I have replaced the batteries and nothing seems to fix the problem
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Mar 21, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Hard wired alarms going off for no reason. how can u turn them off without disconnecting them?
hi,
there may be a battery backup to that hardwired alarm, if it is its a dying battery causing that..
jm
Jan 05, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
Dec 22, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home Security Logo
123 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
